I had a couple related questions, but I didn't want to revive such an old thread so I figured I'd start a new one.
At any rate here goes
1) I know usb has a length limit on the cable - I'm assuming since this cable is converting USB to TTL that I can just splice in an arbitrary length of cat-5 between the two terminal connections, or are there some practical length limitations that I should be aware of?
2) I saw that the ultimate response on whether or not the usb-ttl cable could serve as a replacement for the wifi module was no, since you could not set change any relay states or the like via the Client-Suite PC application. Is that a limitation of Reef Angel itself or just the application? I'm not afraid to dig into putting something together to handle two way communication, but I'd rather not invest a whole lot of time reading through the forum posts to figure out how if the answer is it can't be done.
Thanks much! Looking forward to getting this all up and running!
