T5 Daylight dimming flickering
Posted: Fri Mar 14, 2014 9:36 am
by semik
Hi Guys,
I have Osram balast analog dimmable, when lights go up and down lamps are flickering.
Is it lamps problem or setup of PWM/analog? Can i do something with that?
Thank you for help.
Re: T5 Daylight dimming flickering
Posted: Fri Mar 14, 2014 9:53 am
I'm assuming you got the analog version of RA, right?
Posted: Fri Mar 14, 2014 10:03 am
by semik
Hi rimai, For sure i don't know. I purchased RA from my friend, he told me that he measured dimming port and it goes slowly up and he was informed from you that it is analog even when it is RA not RA+. Can i found it somehow?
Posted: Fri Mar 14, 2014 10:21 am
by semik
To give exact situation, dimming works, but when on dimming lamps are dimming but with flickering.
Posted: Fri Mar 14, 2014 10:49 am
Look underneath the relay box. Does it have a sticker?
Posted: Fri Mar 14, 2014 11:20 am
by semik
There is no sticker. I opened the box and it has jumpers.
How the jumpers should to be set to be analog? 1,2 or 2,3? Box version is 8.1.
Posted: Fri Mar 14, 2014 11:24 am
2-3 for analog
Posted: Fri Mar 14, 2014 11:28 am
by semik
Both jumpers? Mean up and down? Or one is for actinic and second for daylight. Also is is printed Analog/PWM
Posted: Fri Mar 14, 2014 11:29 am
Yes, both on 2-3. Each one of the jumpers is one of the dimming channels.
Posted: Fri Mar 14, 2014 11:44 am
by semik
Roberto, thank you for quick answer and help.
Last question regarding dimming channels.
I have this setup: Next VGA is daylight connected to analog osram ballast and next one is actinic connected to LED moonlight. LED moonlight was purchased from you and it works perfect with jumpers set to 1,2. Question is which jumper is up - the analog one next VGA or actinic? Is moonlight analog or PWM? Thank you again for advice.
Posted: Sat Mar 15, 2014 8:51 am
The one close to the resistors is actinic and should be PWM (1-2) for your moonlights. The one closer to the capacitor is daylight and should be analog (2-3) for your ballasts.
Posted: Sat Mar 15, 2014 6:20 pm
by semik
Thank you Roberto, All is ok now.
