TCP to Serial forwarder
Posted: Sat Mar 15, 2014 2:30 pm
by smande00
So forgive me if this is something that's already available or not needed - I'm just excited I got it working so easily
I hacked together a very quick and dirty app that will accept traffic on TCP port 2000 and forward it to the COM3 port. The long and the short of it is I'm able to use the Android app to control my Reef Angel (including setting relay states) without the Wifi module (I just have the RA connected via the USB->TTL cord to my pc running the app I wrote).
Is there a need for something like this in the community? If so I'd be happy to clean this up a bit for use by others. Just a caveat, it's developed in .NET so this would be a windows only solution.
Re: TCP to Serial forwarder
Posted: Sat Mar 15, 2014 3:40 pm
That would be really cool!!!
I would also like to request 2 things.
1. Host the source code on both github.
2. Permission to post your work in the contribution section of the website.
Posted: Sat Mar 15, 2014 3:56 pm
by smande00
Awesome, I have no problem with either of those. I'll put what I have on github tonight and post the link back on this thread.
Posted: Sat Mar 15, 2014 4:44 pm
You could probably do the same on the mac or linux by using nc (netcat) in a few lines as well. Just so we can cover all OSs
Posted: Sat Mar 15, 2014 4:48 pm
Posted: Sat Mar 15, 2014 5:51 pm
by smande00
lnevo - I agree there's really nothing to these things so I'd be surprised if there's not already multiple options out there on other OSes (or windows for that matter). It certainly shouldn't be hard to put something together if they're not.
At any rate -
https://github.com/smande00/ReefAngelTcpToSerialRelay is the link to what hacked together (with some help from
http://www.codeproject.com/Articles/463 ... -in-Csharp)
I'm git challenged so the solution file didn't make it up to git, but it's not really important. I'll move this to a windows service and include an installer as my next steps. In the interim you can run this as a console app - just update the config if your usb->ttl cable is not running on COM3 or you're not using port 2000 for the wifi module.
Posted: Mon Mar 17, 2014 9:29 am
May I ask for the installable version too?
Just so people can just download and install.
Posted: Mon Mar 17, 2014 9:52 am
by smande00
Sure - I have to actually write the installer still though
I should be able to get that put together tonight or tomorrow at the latest (along with moving the application to a service).
There's also some hardening of the code that needs to get done before I'd recommend anyone actually rely on this - things like gracefully handling errors (rather than ignoring them), reopening the serial port as necessary, etc.
I'll keep the thread updated as things progress.
Posted: Mon Mar 17, 2014 11:14 am
For the record, I was not trying to belittle your contribution. On the contrary, this will be very helpful for many people.
I finally managed to get some syntax for netcat to read/write from the serial port. This should work on MacOS and on Linux
nc -l 2000 > /dev/ttyS0 < /dev/ttyS0
This should open up a tcp port listener for port 2000 on the computer and read/write the IO to /dev/ttyS0. You'd need to change this to whatever serial device your RA comes up as. You may also need to use stty or setserial to set the speed/modes for the serial port. I'm looking into the syntax for those as well, but the command above is the meat of the process.
This should be pretty helpful to those without a wifi adapter who can have a machine permenantly connected. In addition if you kill this off, you shoudl be able to upload new code and then restart the redirection again remotely
Posted: Mon Mar 17, 2014 5:24 pm
by smande00
Hah! No worries, that's not at all how I took it. I'm all for options, and I'm glad to see such a simple built in solution is available on the mac & linux platforms. Something tells me there's probably something similar floating around for windows as well.
Posted: Tue Mar 18, 2014 10:34 am
by smande00
I've added the solution file to git. I've also updated the application to run as a windows service and included an installer/uninstaller.
The link below will take you directly to the compiled binaries. Simply double click the install.bat file to get up and running.
https://github.com/smande00/ReefAngelTc ... r/Binaries
You'll also want to allow port 2000 through the windows firewall (as well as your router if you want to access this externally over the Internet).
Posted: Fri May 30, 2014 3:46 pm
So this allows incoming connection what happens to outgoing for portal updates?
Posted: Tue Jul 15, 2014 10:42 am
by smande00
lnevo wrote:So this allows incoming connection what happens to outgoing for portal updates?
Errr... sorry, obviously haven't checked the forums in awhile. I haven't really messed with the portal to see what it does for updating. I do know it allows Reeftronics to read the controller state and update it's logs for whatever that's worth.
