Help with Coding Multichannel Water Level Sensor and ATO
Paul_Velasco
Post by Paul_Velasco »
Trying to set up my code to do ATO with the multichannel water level sensor
I am trying to turn the ATO pump on at 48% and off above 50%.
ATO = Sensor 4
Relay = Box1_Port7
    ReefAngel.AddSalinityExpansion();  // Salinity Expansion Module
    ReefAngel.AddWaterLevelExpansion();  // Water Level Expansion Module
    ReefAngel.FeedingModePortsE[0] = Port1Bit | Port7Bit;
    ReefAngel.WaterChangePorts = Port5Bit;
    ReefAngel.WaterChangePortsE[0] = Port1Bit | Port7Bit;
    ReefAngel.Relay.On( Port2 );
    ReefAngel.Relay.On( Port3 );
    ReefAngel.Relay.On( Port4 );
    ReefAngel.Relay.On( Port5 );
    ReefAngel.StandardHeater( Port7,750,755 );
    ReefAngel.Relay.DelayedOn( Box1_Port1,10 );
    ReefAngel.StandardLights( Box1_Port3,20,0,8,0 );
    //ReefAngel.WaterLevelATO(4)(Box1_Port7,60,48,51 );
    ReefAngel.RF.SetMode( Constant,30,10 );
    ReefAngel.DCPump.SetMode( Constant,50,10 );
    if (ReefAngel.WaterLevel.GetLevel(4)<=48) ReefAngel.Relay.On(Box1_Port7);
    if (ReefAngel.WaterLevel.GetLevel(4)>=50) ReefAngel.Relay.Off(Box1_Port7);
    ReefAngel.Portal( "Paul_Velasco" );
I get this error? Need to get this going I am on vacation next week.
Error:
sketch_mar16a.cpp: In function 'void loop()':
sketch_mar16a:103: error: 'class ReefAngelClass' has no member named 'WaterLevel'
sketch_mar16a:104: error: 'class ReefAngelClass' has no member named 'WaterLevel'
Oh yeah water levels to not show same on Portal and LCD Screen? I get 50 and 50 on LCD for Portal the numbers are way off???
Re: Help with Coding Multichannel Water Level Sensor and ATO
I'm compiling this code just fine.
Paul_Velasco
Just to close out this issue as it is fixed:
I had tried to look at the waterlevel.h and waterlevel.cpp files in notebook. Windows then associated the files to notebook. Ardunio did not recognize the files.
To fix I uninstalled Ardunio and the Reef Angel IDE Software
Reinstalled the software and compiled the code
Compiled and downloaded to controller :D
What IDE can I use to look at .h and .cpp files from the library so this does not happen? (IOS Windows 7)
I am still having issue with the portal. Will post in that forum.
You should be able to use notepad just fine.
I use eclipse for editing them.
I'm not sure why Arduino didn't recognize them but glad you got it working :)
