Remotely Changing Custom Internal Memory Values?
jgsplat
Post by jgsplat »
Is there a way to remotely change my internal memory values? I do it when I'm home using the wonderful Android App but I haven't got it to work while I'm away yet? Is there a way to change it from the portal? Thank's in advance!
jegillis
Re: Remotely Changing Custom Internal Memory Values?
Post by jegillis »
In the android app you need to setup your away profile with your external ip address, and port (2000) than change profile to away instead of home. If you have a dynamic IP your ip address may frequently change if this is the case a google search will give you lots of options for dealing with that.
https://www.google.com/webhp?tab=ww&aut ... p+dns+free
You can also set some internal values through the Portal, but the Android app has many more options.
You can also do it from any web browser.
http://ip.address.com/mbXXX,YYY
Where xxx= memory location
And yyy= data
You can change mb to mi for ints instead of bytes and you can leave off the ,yyy to query that memory location
jgsplat
Post by jgsplat »
Seems to be working fine now. Thank you so much for all the replies!
jgsplat
Post by jgsplat »
Just as a follow up question. How Dos the Custom Varibles tab work on the app. Can I assign them to a memory location?
