problem controlling jebao from portal
Posted: Sat Mar 29, 2014 8:15 pm
I'm having a problem with my braces...
What I want to do is between the hours of 8 am and 9 pm be able to change my jebao from the portal and from 9 pm to 8 am only have it run what I have in the code, and not be able to switch it...and during that 8 am to 9 pm, have the "custom" switch from the portal run else mode...I keep getting an error about a brace being expected...
What am I doing wrong? am I missing a brace somewhere? Or what am I doing wrong...
Rob
Rob
ReefAngel.WaterChangePorts = Port5Bit;
ReefAngel.LightsOnPorts = Port1Bit | Port2Bit | Port3Bit | Port4Bit;
ReefAngel.OverheatShutoffPorts = Port1Bit | Port2Bit | Port3Bit | Port4Bit | Port7Bit;
ReefAngel.CustomLabels[0]="Frag Pump";
ReefAngel.CustomLabels[1]="Actinics";
ReefAngel.CustomLabels[2]="Daylights";
ReefAngel.CustomLabels[3]="Frag LED";
ReefAngel.CustomLabels[4]="ATO Pump";
ReefAngel.CustomLabels[5]="Reactor";
ReefAngel.CustomLabels[6]="Heater";
ReefAngel.CustomLabels[7]="Fan";
ReefAngel.ActinicLights( Port2 );
ReefAngel.DayLights( Port3 );
ReefAngel.ActinicLights( Port4 );
ReefAngel.SingleATOLow( Port5 );
ReefAngel.StandardFan( Port8 );
//ReefAngel.DCPump.UseMemory = false;
if (hour()>=8 && hour()<21)
if (ReefAngel.DCPump.Mode==Custom)
ReefAngel.PWM.SetActinic(ElseMode(60, 20, true));
} else{
ReefAngel.DCPump.UseMemory = true;}
ReefAngel.PWM.SetActinic(LongPulseMode(65,40, 60, true));
ReefAngel.Portal( "psyrob" );
static unsigned long LastChange=millis(); // Set the inital time that the last change occurred
static int Delay = random( 500, 3000); // Set the initial delay
static int NewSpeed = MidPoint; // Set the initial speed
static int AntiSpeed = MidPoint; // Set the initial anti sync speed
if ((millis()-LastChange) > Delay) // Check if the delay has elapsed
Delay=random(500,5000); // If so, come up with a new delay
int ChangeUp = random(Offset); // Amount to go up or down
if (random(100)<50) // 50/50 chance of speed going up or going down
LastChange=millis(); // Reset the time of the last change
if (WaveSync)
return NewSpeed;
return AntiSpeed;
