Pump Schedule for WP-25
Posted: Sun Mar 30, 2014 5:42 pm
I finally got my wp-25 started w/ the help of lnevo and now I am trying my hand at scheduling the pump modes. Lee helped me w/ my initial code here:
Now I want to add a schedule to my pumps. I want to run constant mode of 30% between the hours of 10pm and 1pm. From 1pm to 10pm, I want to run the else mode code at 35% +/- 5%. Please note that the power for the pumps are preliminary and I will be adjusting them as I play and fine tune the pump for my setup.
For the code below, I have assumed that in order to run a schedule, the pump code has to be hard coded. The code Lee (or you if you're reading
) helped me w/ utilizes the portal settings to adjust the speed and the fluctuation of else mode. I am okay w/ this being hard coded in since once I have it tuned, I won't be messing with it anymore. Here's the code that I came up w/ thanks to some research and copy/pasting.
Am I close?
ReefAngel.FeedingModePorts = Port1Bit | Port5Bit | Port6Bit;
ReefAngel.WaterChangePorts = Port1Bit | Port2Bit | Port5Bit | Port6Bit | Port7Bit;
ReefAngel.Relay.On( Port2 );
ReefAngel.Relay.On( Port5 );
ReefAngel.DayLights( Port3 );
ReefAngel.ActinicLights( Port4 );
if (ReefAngel.DCPump.Mode==Custom) {
ReefAngel.PWM.SetActinic( ElseMode(ReefAngel.DCPump.Speed,ReefAngel.DCPump.Duration,true)); // ElseMode on sync mode, 35 +/- 5%
ReefAngel.Portal( "howaboutme" );
if (WaveSync)
return NewSpeed;
return AntiSpeed;
if (hour()>=22 && hour()<13)
ReefAngel.PWM.SetActinic( ConstantMode(30,true) ); // Constant at 30% on sync mode
else if (hour()>=13 && hour()<22)
ReefAngel.PWM.SetActinic( ElseMode(34,5,true)); // ElseMode on sync mode, 35 +/- 5%
if (WaveSync)
return NewSpeed;
return AntiSpeed;
