I am trying to get a sunrise, sunset from east to west accordingly, lightning is great, but I want to work on the sunrise and sunset first, then later down the road I will try to incorporate storms when I am better at figuring out this RA language....
I also have the 6 channel dimming expansion already connected and running two wp60's and two wp 40's.
I have 214 LED's over an eight foot span, the Blue's and whites are grouped together in sequence, with eight to ten LED's of each color on individual channels. Then I have UV/Cyan spread out over the length of the heatsinks on a seperate channel, also I have a channel for red that is spread out over the length of the tank, and a channel for green spread out over the tank. These are the list of my channels, starting from east to west on my tank, (except for the reds, greens, and uv/cyan which are spread out on individual channels)
1. 1st Blue on east end
2. 1st white on east end
3. 2nd blue channel
4. 3rd blue channel
5. 2nd white channel
6. 4th blue channel
7.5th blue channel
8. 3rd white channel
9. 6th blue channel
10. 4th white channel
11. 7th blue channel
12. 5th white channel
13. 8th blue channel
14. UV/Cyan channel
15. Green Channel
16. Red channel
The colors are all mixed very well across 4 linear heatsinks, I dont have any color banding, or "rainbow effects" what so ever. I have been using these lights for over a year now and are growing coral very well.
I just got my DC Pump code figured out, and now its time to do this lighting. Ill paste my current code first, and then I will paste the test code Roberto sent me second.
ReefAngel.WaterChangePorts = Port1Bit | Port4Bit;
ReefAngel.Relay.On( Port4 );
ReefAngel.MoonLights( Port5 );
ReefAngel.DayLights( Port6 );
ReefAngel.DosingPumpRepeat1( Box1_Port1 );
ReefAngel.DosingPumpRepeat2( Box1_Port2 );
ReefAngel.DCPump.ExpansionChannel[1] = Sync;
ReefAngel.DCPump.ExpansionChannel[2] = AntiSync;
ReefAngel.DCPump.ExpansionChannel[3] = AntiSync;
//Night Mode at 30%
if (hour()<6 || hour()>=22) {
ReefAngel.DCPump.Speed=30;
static int rmode;
// Add Else Mode definition..
const int Else=16;
byte modes[] = { ReefCrest, Lagoon, Constant, TidalSwell, ShortPulse, LongPulse, Else };
changeMode=false;
static unsigned long feeding;
if (now()-feeding<9000) {
// Continue NTM for 150 minutes
} else if (now()%SECS_PER_DAY<21600 || now()%SECS_PER_DAY>=79200) { // 6AM / 10pm
// Night mode (go to 30%)
if (rmode==Else) {
ReefAngel.DCPump.Speed=ElseMode(InternalMemory.DCPumpSpeed_read(),20,true ); // ElseMode on sync mode, Portal Speed Setting +/- 20%
ReefAngel.Portal( "heatdissipation" );
if (WaveSync)
return NewSpeed;
return AntiSpeed;
#include <rtc_clock.h>
ReefAngel.Init();
for (int a=0;a<16;a++)
CustomExpansion(0x41,a,30);
void CustomExpansion(byte id, byte channel, byte percentage)
Wire.beginTransmission(id);
Wire.write(0);
Wire.write(0xa1);
Wire.endTransmission();
int newdata=(int)(percentage*40.95);
Wire.write(0x8+(4*channel));
Wire.write(newdata&0xff);
Wire.write(newdata>>8);
