16 channel custom board code
Posted: Sun Mar 30, 2014 5:51 pm
by heatdissipation
Roberto made me a 16 channel board, I got it a few weeks ago, but I am just now getting around to trying to set it up. I spliced it into my current light controller so that I can test and fine tune it before I use it as my only control of my lights.
I am trying to get a sunrise, sunset from east to west accordingly, lightning is great, but I want to work on the sunrise and sunset first, then later down the road I will try to incorporate storms when I am better at figuring out this RA language....
I also have the 6 channel dimming expansion already connected and running two wp60's and two wp 40's.
I have 214 LED's over an eight foot span, the Blue's and whites are grouped together in sequence, with eight to ten LED's of each color on individual channels. Then I have UV/Cyan spread out over the length of the heatsinks on a seperate channel, also I have a channel for red that is spread out over the length of the tank, and a channel for green spread out over the tank. These are the list of my channels, starting from east to west on my tank, (except for the reds, greens, and uv/cyan which are spread out on individual channels)
1. 1st Blue on east end
2. 1st white on east end
3. 2nd blue channel
4. 3rd blue channel
5. 2nd white channel
6. 4th blue channel
7.5th blue channel
8. 3rd white channel
9. 6th blue channel
10. 4th white channel
11. 7th blue channel
12. 5th white channel
13. 8th blue channel
14. UV/Cyan channel
15. Green Channel
16. Red channel
The colors are all mixed very well across 4 linear heatsinks, I dont have any color banding, or "rainbow effects" what so ever. I have been using these lights for over a year now and are growing coral very well.
I just got my DC Pump code figured out, and now its time to do this lighting. Ill paste my current code first, and then I will paste the test code Roberto sent me second.
    ReefAngel.AddSalinityExpansion();  // Salinity Expansion Module
    ReefAngel.AddPHExpansion();  // pH Expansion Module
    ReefAngel.FeedingModePorts = Port4Bit;
    ReefAngel.WaterChangePorts = Port1Bit | Port4Bit;
    ReefAngel.OverheatShutoffPorts = Port1Bit;
    ReefAngel.Relay.On( Port4 );
    ReefAngel.StandardHeater( Port1 );
    ReefAngel.MoonLights( Port5 );
    ReefAngel.DayLights( Port6 );
    ReefAngel.DosingPumpRepeat1( Box1_Port1 );
    ReefAngel.DosingPumpRepeat2( Box1_Port2 );
    ReefAngel.DCPump.ExpansionChannel[0] = None;
    ReefAngel.DCPump.ExpansionChannel[1] = Sync;
    ReefAngel.DCPump.ExpansionChannel[2] = AntiSync;
    ReefAngel.DCPump.ExpansionChannel[3] = AntiSync;
    //Night Mode at 30%
     if (hour()<6 || hour()>=22) {
ReefAngel.DCPump.Mode=Constant;
ReefAngel.DCPump.Speed=30;
    // Add random mode if we set to Mode to Custom in portal
static int rmode;
// Add Else Mode definition..
const int Else=16;
byte modes[] = { ReefCrest, Lagoon, Constant, TidalSwell, ShortPulse, LongPulse, Else };
if (now()%SECS_PER_DAY==0 || changeMode==true) { // Change at midnight or if controller rebooted
rmode=random(100)%sizeof(modes); // Change the mode once per day to pick from our array
changeMode=false;
static unsigned long feeding;
if (now()-feeding<9000) {
  // Continue NTM for 150 minutes
  ReefAngel.DCPump.Mode=NutrientTransport;
} else if (now()%SECS_PER_DAY<21600 || now()%SECS_PER_DAY>=79200) { // 6AM / 10pm
  // Night mode (go to 30%)
} else if (InternalMemory.DCPumpMode_read()==11) {
  if (rmode==Else) {
    ReefAngel.DCPump.Speed=ElseMode(InternalMemory.DCPumpSpeed_read(),20,true );    // ElseMode on sync mode, Portal Speed Setting +/- 20%
  } else {
    ReefAngel.DCPump.Mode=modes[rmode];  // Put the mode to the random mode :)
} else {
    ReefAngel.Portal( "heatdissipation" );
 static unsigned long LastChange=millis(); // Set the inital time that the last change occurred
 static int Delay = random( 500, 3000); // Set the initial delay
 static int NewSpeed = MidPoint; // Set the initial speed
 static int AntiSpeed = MidPoint; // Set the initial anti sync speed
 if ((millis()-LastChange) > Delay) // Check if the delay has elapsed
 Delay=random(500,5000); // If so, come up with a new delay
 int ChangeUp = random(Offset); // Amount to go up or down
 if (random(100)<50) // 50/50 chance of speed going up or going down
 LastChange=millis(); // Reset the time of the last change
 if (WaveSync)
 return NewSpeed;
 return AntiSpeed;
This is the test code I have, I loaded it and it did light everything up after I got the board spliced into my current setup. It was quite dim, but I believe that the test code wasnt putting out 100%
#include <rtc_clock.h>
  ReefAngel.Init();
  for (int a=0;a<16;a++)
    CustomExpansion(0x41,a,30);
void CustomExpansion(byte id, byte channel, byte percentage)
  Wire.beginTransmission(id);
  Wire.write(0);
  Wire.write(0xa1);
  Wire.endTransmission();
  int newdata=(int)(percentage*40.95);
  Wire.write(0x8+(4*channel));
  Wire.write(newdata&0xff);
  Wire.write(newdata>>8);
So I need help pointing me in the right direction on what, if anything I need to add to my libraries, and a rough draft on the code that it would take to light this up. Any and all help would be so appreciated, as I know this isnt really the run of the mill questions you are all used to getting. Thanks
Re: 16 channel custom board code
Posted: Mon Mar 31, 2014 1:23 pm
by heatdissipation
I'm not sure if I can do this one on my own right now. Maybe in the future I will be able to, but right now I am still learning this code.
Posted: Mon Mar 31, 2014 4:08 pm
What is that you want to do with each channel?
We need a graph or something to know what each channel is going to be like for a 24hr period.
Posted: Mon Mar 31, 2014 8:52 pm
by heatdissipation
To start off I just want a default program that works. Just a parabola pattern starting at 0 ramping up to say 80% and then back to zero. I want to use this until I can put together the code that will do the more advanced functions. But this will be the program I can upload to run while I'm testing out other programs
Posted: Tue Apr 01, 2014 7:14 am
Try this:
  //Night Mode at 30%
  static int rmode;
  const int Else=16;
  byte modes[] = {
    changeMode=false;
    if (rmode==Else) {
    else {
  else {
  CustomExpansion(0x41,0,PWMParabola(8,10,18,20,5,95,1)); // Set channel 0 to parabola from 8:10am to 6:20pm with % from 5 to 95 and 1% when at night cycle.
  if (WaveSync)
    return NewSpeed;
    return AntiSpeed;
  Wire.write(0);
  Wire.write(0xa1);
Posted: Tue Apr 01, 2014 9:56 am
by heatdissipation
That sketch compiled fine, but only lit up channel one
Posted: Tue Apr 01, 2014 10:10 am
You need to add the rest of the channels. I think he only gave you one as an example
Posted: Tue Apr 01, 2014 12:05 pm
by heatdissipation
So I need to repeat that line of code 15 more times substituting the "0" for each channel
Posted: Tue Apr 01, 2014 12:10 pm
You got it and you can adjust the parabola arguments for each channel then as well. for % or times, etc.
Posted: Wed Apr 02, 2014 6:13 am
by heatdissipation
Which of the zeros are specifying the channel? I know what everything else is, but I am not sure what (0x41,0, means
Posted: Wed Apr 02, 2014 6:21 am
by heatdissipation
One more thing, "8,10,18,20". That is specifying the time. From 810 am - 620 pm. What increments can I increase the time, can I do one minute increments and stagger them to create the sunrise and sunset?
Posted: Wed Apr 02, 2014 7:39 am
The 0 right before PWMParabola is the one that specifies the channel.
The rest you have correct. The 8 is hour the 10 is minutes same for 18:20. You can specify exactly what time using those 4 fields.
One thing you'll want to change maybe is the last argument the ,1. That will make the default for all channels 1% when not in the specified times. You may want that to be 0%
Posted: Wed Apr 02, 2014 11:18 am
by heatdissipation
Thank you so much guys, I finally have my default sketch, all channels are lit up, pumps working great, now I can start playing around and getting creative, I still have a couple small problems to work out, my PH reads 1 and my salinity reads 6, but I havent really tried dialing them in yet. I did calibrate both, but something isnt working right there, just havent dug into it yet to see what it is.
Posted: Wed Apr 02, 2014 12:03 pm
by heatdissipation
This is my default sketch, I have all the times set like I want them for my lights, I realize there is some code for my pumps that I am not using in this sketch at the end, but I forgot to delete it when I compiled this sketch, everything works like I want it to, so I am considering this my default sketch.
  //Night Mode at 30%
   CustomExpansion(0x41,0,PWMParabola(7,10,21,30,5,95,1)); // Set channel 0 to parabola from 8:10am to 6:20pm with % from 5 to 95 and 1% when at night cycle.
   CustomExpansion(0x41,1,PWMParabola(7,12,21,28,5,85,0));
   CustomExpansion(0x41,2,PWMParabola(7,14,21,26,5,95,0));
   CustomExpansion(0x41,3,PWMParabola(7,16,21,24,5,95,1));
   CustomExpansion(0x41,4,PWMParabola(7,17,21,25,5,85,0));
   CustomExpansion(0x41,5,PWMParabola(7,18,21,25,5,95,0));
   CustomExpansion(0x41,6,PWMParabola(7,20,21,23,5,95,1));
   CustomExpansion(0x41,7,PWMParabola(7,22,21,22,5,85,0));
   CustomExpansion(0x41,8,PWMParabola(7,23,21,21,5,95,0));
   CustomExpansion(0x41,9,PWMParabola(7,24,21,20,5,85,0));
   CustomExpansion(0x41,10,PWMParabola(7,25,21,19,5,95,1));
   CustomExpansion(0x41,11,PWMParabola(7,26,21,18,5,85,0));
   CustomExpansion(0x41,12,PWMParabola(7,27,21,17,5,95,1));
   CustomExpansion(0x41,13,PWMParabola(7,40,21,05,50,100,5));
   CustomExpansion(0x41,14,PWMParabola(7,30,21,25,20,60,0));
   CustomExpansion(0x41,15,PWMParabola(7,02,21,15,20,60,0));
  if (WaveSync)
    return NewSpeed;
    return AntiSpeed;
  Wire.write(0);
  Wire.write(0xa1);
Posted: Wed Apr 02, 2014 12:41 pm
Wise to back it up here :) Great job in getting everything going. The ElseMode is an unused function so no harm or foul to leave it there, unless you have a standard RA.
Posted: Wed Apr 02, 2014 4:37 pm
by heatdissipation
Thanks for the words of encouragement, what may seem easy now was once tough to learn for everyone. I struggled more than I thought I would just figuring out this simple sketch. I can write and troubleshoot CNC code in my sleep, but this is all new to me, now to keep the two separated. I find myself wanting to put "if" and "else" statements in CNC code at work now. :-)
