jaebo code not working,
Ademster
Post by Ademster »
as title says jaebo not working I am using the code below.
I see the values changing on the controller but the pumps isn't going what it shows.
    ReefAngel.AddSalinityExpansion();  // Salinity Expansion Module
    ReefAngel.AddWaterLevelExpansion();  // Water Level Expansion Module
    ReefAngel.FeedingModePorts = Port1Bit | Port2Bit;
    ReefAngel.OverheatShutoffPorts = Port3Bit;
    ReefAngel.Relay.On( Port4 );
    ReefAngel.Relay.On( Port7 );
    ReefAngel.Relay.DelayedOn( Port2 );
    ReefAngel.Wavemaker1( Port5 );
    ReefAngel.StandardATO( Box1_Port2 );
    ReefAngel.CO2Control( Box1_Port3 );
    ReefAngel.PHControl( Box1_Port4 );
    ReefAngel.PWM.Channel0PWMSlope();
    ReefAngel.PWM.Channel1PWMSlope();
    ReefAngel.PWM.Channel2PWMSlope();
    ReefAngel.PWM.Channel3PWMSlope();
        if (hour()>=8 && hour()<11)
      ReefAngel.PWM.SetDaylight( TidalSwellMode(40,true) ); // Tidal Swell at 40% on sync mode
    else if (hour()>=11 && hour()<12)
      ReefAngel.PWM.SetDaylight( ReefCrestMode(50,20,true) ); // ReefCrest at 50% + - 20 on sync mode
    else if (hour()>=12 && hour()<13)
      ReefAngel.PWM.SetDaylight( millis()%1000>800?80:0); // WaveMode on sync mode
    else if (hour()>=13 && hour()<14)
      ReefAngel.PWM.SetDaylight( ReefCrestMode(70,20,true) ); // ReefCrest at 70% + - 20 on sync mode
    else if (hour()>=15 && hour()<18)
      ReefAngel.PWM.SetDaylight( NutrientTransportMode(77,90,3000,true) ); // Nutrient Transport on sync mode
    else if (hour()>=21 && hour()<24)
      ReefAngel.PWM.SetDaylight( millis()%1000>800?70:0); // Wave on sync mode
      ReefAngel.PWM.SetDaylight( LongPulseMode(40,40,10,true) ); // Long pulse at 40% with 10s pulse on syncy mode
                ReefAngel.PWM.SetDaylight(0);
      if (ReefAngel.DisplayedMenu==WATERCHANGE_MODE)
    ReefAngel.Portal( "ademster" );
Adam
58 Gal
Ademster
Re: jaebo code not working,
Post by Ademster »
should also mention using the wizard. tidel swell still no pump action
Adam
58 Gal
Piper
Post by Piper »
Change:
to
and see if that helps.
Ademster
Post by Ademster »
I switched it over to the actinic side and nothing either.
I thinking the dimming ports on the relay box are bad.
sucks. I was going to buy one more cable and get another pump...
Adam
58 Gal
Piper
Post by Piper »
You tried setting ReefAngel.DCPump.UseMemory to false also? What do you have the DC pump set to on the portal?
Do you have multi-meter you can put on the dimming ports to measure the voltage?
Have you ever used the dimming ports before?
If your box is one of the early versions, it did not have the booster built-in.
It was an optional item. You would need to open the box to find out.
Let me know which revision or take some photos.
Ademster
Post by Ademster »
I will try again later tonight once the lights go out. and I will unplug everything and open the box up.
I bought it 2 years ago I think. I used the dimming ports for a short period of time. while I was saving to buy the dimming expansion.
Adam
58 Gal
Ademster
Post by Ademster »
relay box dimming ports haven't been used in almost 2 years.
Adam
58 Gal
Ademster
Post by Ademster »
I tested for output voltage on the relay box, nothing. I have the DC pump set to 100% constant. No voltage on either ports.
Guess I will continue to use the stock jaebo controller.
Anyone need a jaebo pump cord?
Adam
58 Gal
davaraj
Post by davaraj »
Ademster wrote:I tested for output voltage on the relay box, nothing. I have the DC pump set to 100% constant. No voltage on either ports.
I had a similar problem with the relay box, where the dimming channels were not working. Roberto advised that I change chip LM358P on the relay board. I did that and the dimming channels were functioning after that.
Dr Davaraj
Did you open the box to check?
Ademster
Post by Ademster »
No, I just tested for voltage on the dimming port pins. with it commanding both actinic and daylight channel 100% no voltage..
Adam
58 Gal
I meant open the box to see if you have old style box or not.
If it is one of the old style boxes, you will need a PWM booster add-on.
Check the revision of the board or take a photo.
Ademster
Post by Ademster »
I'll open it up tonight
Adam
58 Gal
Ademster
Post by Ademster »
Revision 8.0 looks like the IC chip fried. burn marks all around the ic chip and also you can see it got hot around the legs.
Guess I have to order one and replace it
Adam
58 Gal
Ademster
Post by Ademster »
Adam
58 Gal
Looks like saltwater damage.
