Why can't I retrieve data from my controller when using cellular data network on my phone?
Through android app and web browser on my phone I can't connect to my away host when connected to cellular data. When I connect to Wifi or Ethernet on my internal network at home it works, and when I connect to Wifi or Ethernet network at my work it works. I can only retrieve data when I'm connected to a Wifi network from my cell phone (Internal or External Wifi Networks).
Portal works from Wifi and Cellular Data network. My Port forwarding is setup correctly. Check my Web Banner for last update.
This is what I done so far to look what the problem could be.
1.) Hard reset the wifi module and setup it again with no luck retrieving data on cellular data network.
2.) Used both DNS accounts for my host (No-ip and DynDns) Both off them are closed when trying to open port 2000 from cellular data network, But if I connect to wifi network port 2000 are open and retrieving data.
3.) Used my friends wifi module with the same settings with no luck retrieving data on cellular data network.
4.) Changed to my old router which the Wifi Module worked before on cellular data with no luck this time, so I changed back to my newest router.
What do you guys think the problem could be
