i received my meanwell dimmable driver
little question
it is best to connecte the driver in standard power bar on connecte on the reef angel
because if i connecte to the reef angel the port exemple 2 is off, if i need to add something to my pde for on and off the port under o% off dimmable
or just plug on another power bar and recup the port
thank you
the french guy
dimmable driver
Re: dimmable driver
You can do one or the other.
It's up to you.
Anything with less than around 15% would make the driver to look like it is off.
It's up to you.
