Clueless Noob!!
Posted: Sat Apr 05, 2014 10:55 am
by Christo
Hi Guys!
I Just recieved my Reef Angel unit and Wifi Atachement! What do I have to do now?
Got no Idea!
Thanx
Re: Clueless Noob!!
Posted: Sat Apr 05, 2014 11:46 am
Download the user manual and the Reef Angel Installer on the website.
Install the installer and use the Reef Angel Wizard to customize your controller if needed.
Re: Clueless Noob!!
Posted: Sun Apr 06, 2014 12:54 am
by Christo
Okay everything is Done!
But like most I'm struggling with the wifi. After Using the wifi utility setup
on the last step it says "unable to setup port forwarding this has to be done manually"
How do we go about this?
Thanx
Re: Clueless Noob!!
Posted: Sun Apr 06, 2014 4:35 am
by Sebyte
Port forwarding has to be setup in your router.
Check in your user manual for the router and also look at http://forum.reefangel.com/./viewtopic. ... forwarding
Re: Clueless Noob!!
Posted: Sun Apr 06, 2014 6:59 am
by Christo
Okay! Been strugling the whole day!! I logged into my router and it does not have a place where I can setup Port forwarding!!!
Any Help
Re: Clueless Noob!!
Posted: Sun Apr 06, 2014 9:39 am
Sometimes its listed under Applications & Gaming, what model router do you have?
Re: Clueless Noob!!
Posted: Sun Apr 06, 2014 9:54 am
by Christo
NETGEAR N300 Wireless ADSL2+ v2
Re: Clueless Noob!!
Posted: Sun Apr 06, 2014 9:55 am
by Christo
For some reason the v2 Is different then all the others!!
Re: Clueless Noob!!
Posted: Sun Apr 06, 2014 10:41 am
by Christo
Okay!! Done some more reading!! The router I have use Inbound and outbound rules!! Any Help welcome Please!!!!!!
Re: Clueless Noob!!
Posted: Sun Apr 06, 2014 11:39 am
Its an inbound rule
Re: Clueless Noob!!
Posted: Sun Apr 06, 2014 12:38 pm
by Christo
Now what do I do?
Re: Clueless Noob!!
Posted: Sun Apr 06, 2014 10:01 pm
by Christo
Please Guys! Still need help Here? Everything is setup so far! The Wifi works thru my home network when I use my iPhone but cant access it thru the internet!'
Re: Clueless Noob!!
Posted: Mon Apr 07, 2014 5:03 am
by Christo
Any Takers on some Help?
Re: Clueless Noob!!
Posted: Mon Apr 07, 2014 5:17 am
by cosmith71
What is your model number? Should be on a sticker somewhere on the router.
Re: Clueless Noob!!
Posted: Mon Apr 07, 2014 5:21 am
You just need to create a rule to allow port 2000 to connect to the ip address of the reefangel. There should be a form to add a new rule. Post some screenshots if your that stuck.
Re: Clueless Noob!!
Posted: Mon Apr 07, 2014 8:01 am
Also, try this:
www.simpleportforwarding.com
I think is some sort of key press generator that presses the right keys for you. I've heard from other users that it works.
