WIFI strange behavior....
Posted: Thu Apr 10, 2014 3:46 pm
by gabe81
Hi to all!
Today i received my RA+ (in 7 days from SF to Italy ... very satisfied :mrgreen: ). I installed under the tank and put it to work immediately ... all works very fine but i have a strange problem with wifi module ... i setup the module with wifi utility, everything workend and the router set the IP 192.168.2.240 to the wifi module, if i make a scan of the network i see the RA but i can't connect with the browser at 192.168.2.240:2000 address ... the green led blink slow and i can see the upgrades to the Portal page of the forum!! Even the iphone app to work if I enter the IP address in the setup!
RA seems to be invisible in the network, but communicates with the forum! Possible? :roll:
Thank's a lot for helping!
PS: so sorry for my bad English ... I hope you can understand :oops: :oops:
Re: WIFI strange behavior....
Posted: Thu Apr 10, 2014 4:41 pm
If you are using internet explorer, you must type http:// in front of it.
Try clicking here:
http://192.168.2.240:2000
Posted: Thu Apr 10, 2014 10:52 pm
by gabe81
No, i use safari on mac. I try with and without http:/, i try with chome... but nothing. Neither the ios app work with that address.
Posted: Fri Apr 11, 2014 2:49 am
by gabe81
Upgrade: i try to connect the wifi module to wifi_Utility but ... :
Opening Serial Port...
Verifying speed at 9600 baud
** ERROR: Connecting to /dev/tty.usbserial-A603IBH2
** Additional installation required to use serial, read the console below.
Yesterday, when i setup for the first time, all works fine ... :?
Posted: Fri Apr 11, 2014 8:58 am
by gabe81
I was able to communicate with the module WIFI "downgrading" the WIFI_utility to version 1.0.9. I reconfigured the WIFI, continues to work perfectly on the portal page but does not work the internal network.
Posted: Fri Apr 11, 2014 9:15 am
Try from a different device. Also check the firewall settings on your workstation. If the phone apps work then you should be good to go. Its also possible that your IP on the reefangel is not what you think and the router may have reassigned it.
Posted: Fri Apr 11, 2014 10:40 am
by gabe81
I see the address in network scan and in the page of the device connected to the router ... then i think it's the correct address. The iphone app don't work ... ! Work the portal dash pannel ..
PS: thank's for answers
Posted: Fri Apr 11, 2014 10:48 am
If you are using your phone, make sure your phone is connected to your wifi network and not on 3G.
Posted: Fri Apr 11, 2014 10:49 am
Does it let you turn ports on / off from the Portal?
If you use the address that shows in the portal on your phone does it work?
Posted: Fri Apr 11, 2014 1:11 pm
by gabe81
No, the switch on the portal don't work, i can only see the parameter and graphics. iPhone is connected under the network.
Posted: Fri Apr 11, 2014 3:25 pm
So that means your ra is on the network sending data outgoing. Thats good but it confirms that your port forwarding is not setup properly and i believe its because your ra address has changed ip. You need to configure a dhcp reservation in your router for it or configure the wifi module with a static ip
Posted: Sat Apr 12, 2014 12:42 am
by gabe81
I reserved a static IP related to the MAC address out of the DHCP range. New address of the RA is 192.168.2.95. I connect WIFI module to WIFI_UTILITY and I have verified that the new address is 192.168.2.95:2000.
But the situation remain the same ... i can't connect to internal web server and iphone app don't work.
Posted: Sat Apr 12, 2014 1:41 am
by Amos Poh
I get this too. Try unplug the Wifi attachment and plug it in again.
Posted: Sat Apr 12, 2014 7:52 am
by gabe81
I have try million times ... :D
Posted: Sat Apr 12, 2014 8:07 am
I'm starting to think that your cable may be bad.
Can you take photos of both ends?
Do you have a multimeter to check for continuity?
When you connect to http://192.168.2.95:2000, does the wifi attachment blink the orange leds?
Orange represents data being transfered.
Posted: Sun Apr 13, 2014 8:09 am
by gabe81
Yes i have a multimeter, what should I check? Tomorrow i post a picture of the cable (the tank is in my office).
Posted: Sun Apr 13, 2014 1:52 pm
Disconnect both ends and check if the cable is not broken in the middle by checking continuity on both ends
Posted: Sun Apr 13, 2014 11:47 pm
by gabe81
I try continuity on both cable, it's all ok. Every color on one side correspond exactly on the color on the other. This is the photo of the cable:
image di Gabriele Lucentini, su Flickr
Posted: Mon Apr 14, 2014 7:23 am
It is not your cable then.
The only thing I can think of is the router, but it shouldn't be blocking traffic by default.
Posted: Mon Apr 14, 2014 7:41 am
by gabe81
no ... i have many printer and net device ... that allow connection by web interface and all works fine ..., all the router parameter are "standard". The router is a SONICWALL TZ100.
Posted: Mon Apr 14, 2014 11:46 pm
by gabe81
it may depend on some parameters in the access point configuration?
My settings are:
Country code: IT
Radio mode: 2,4 ghz 802.11.n/g/b mixed
Radio band: auto
Primary channel: auto
Secondary channel: auto
Security: WPA2 - AUTO - PSK
Cipher type: AES
Group key update: By Timeout
Interval (sec): 86400
In the list of the connected device i see the RA wifi module:
n MAC AID SIGNAL SPEED TIMEOUT
2. 00:06:66:21:E1:2C Authenticated Associated 2 39% 24 Mbps 300s
Posted: Tue Apr 15, 2014 8:17 am
I don't think so.
Can you ping the wifi attachment?
When you try to connect with browser, does the orange LED in the wifi attachment blink?
Posted: Tue Apr 15, 2014 9:21 am
by gabe81
no i can't ping it. No orange led don't blink, it blink something ... i think when RA send data to the portal.
Posted: Sat May 31, 2014 2:42 am
by gabe81
Something news ... ! Now RA it's attainable from web browser, i can view the /wifi page and i can use all function (work great). But it continues to be inaccassibile from the outside and from the iPad/iphone app ...
I don't make any changes to the network or wifi module configuration ... it just works now .... :?:
Posted: Sat May 31, 2014 7:57 am
To be able to connect outside your wifi network, you will need to setup port forwarding in your router.
