Limmit which screen text is displayed on
Posted: Fri Apr 11, 2014 11:43 pm
Ok next question, Im using the new screen layout and wanted to put a large text of the temp1 in the extra space provided the below code does that for me but the problem is it is drwn over the splash screen and any sub menus.
Is there a way to get it to display on just the home screen..
#include <ReefAngel_Colors.h>
/////// Place global variable code below here
ReefAngel.AddStandardMenu();
ReefAngel.Use2014Screen();
ReefAngel.AddDateTimeMenu();
ReefAngel.FeedingModePorts = Port3Bit | Port7Bit | Port8Bit;
ReefAngel.WaterChangePorts = Port1Bit | Port2Bit | Port3Bit | Port4Bit | Port5Bit | Port7Bit | Port8Bit;
ReefAngel.LightsOnPorts = Port4Bit | Port5Bit;
ReefAngel.OverheatShutoffPorts = Port2Bit | Port4Bit | Port5Bit | Port6Bit;
ReefAngel.Relay.On( Port7 );
ReefAngel.CustomLabels[0]="ATO";
ReefAngel.CustomLabels[1]="Heater";
ReefAngel.CustomLabels[2]="FAN";
ReefAngel.CustomLabels[3]="Kessil";
ReefAngel.CustomLabels[4]="LED";
ReefAngel.CustomLabels[5]="Refugium";
ReefAngel.CustomLabels[6]="F Pump";
ReefAngel.CustomLabels[7]="C Pump";
ReefAngel.StandardATO( Port1 );
ReefAngel.StandardHeater( Port2 );
ReefAngel.StandardFan( Port3 );
ReefAngel.DayLights( Port4 );
ReefAngel.ActinicLights( Port5 );
ReefAngel.MoonLights( Port6 );
ReefAngel.Relay.Set(Port5, !ReefAngel.Relay.Status(Port4));
char text[7];
byte TempColor = COLOR_GREEN;
int TempLow = InternalMemory.HeaterTempOn_read();//789
int TempHigh = InternalMemory.HeaterTempOff_read();//797
if(ReefAngel.Params.Temp[T1_PROBE] < TempLow){TempColor = COLOR_BLUE;}
if((ReefAngel.Params.Temp[T1_PROBE] >= TempLow)&&(ReefAngel.Params.Temp[T1_PROBE] <= TempHigh)){TempColor = COLOR_GREEN;}
if(ReefAngel.Params.Temp[T1_PROBE] > TempHigh){TempColor = COLOR_RED;}
ReefAngel.LCD.DrawHugeNumbers(TempColor, COLOR_WHITE, 30, 70, text);
ReefAngel.Portal( "xxxxxx" );
