#include <ReefAngel_Wifi.h>
#include <ReefAngel_EEPROM.h>
#include <ReefAngel_ATO.h>
#include <ReefAngel_LED.h>
#include <ReefAngel_Relay.h>
#include <ReefAngel_PWM.h>
#include <ReefAngel_Timer.h>
#include <ReefAngel_Memory.h>
int DP3_Timer = InternalMemory.DP1Timer_read() * 4;
//Disegno schermo principale
 // Change the 30 to adjust the horizontal position of the text on the screen, max 20-21 chars
  ReefAngel.LCD.DrawText(DefaultFGColor, DefaultBGColor, 15, 15, "LukeLuke's Cube");
  ReefAngel.LCD.DrawDate(6, 112);
  ReefAngel.LCD.DrawMonitor(15, 35, ReefAngel.Params,
  ReefAngel.LCD.DrawMonitor(15, 60, ReefAngel.Params);
  ReefAngel.LCD.DrawText(DefaultFGColor, DefaultBGColor, 6, 70, "DP1:");
  ReefAngel.LCD.DrawText(DefaultFGColor, DefaultBGColor, 31, 70, InternalMemory.DP1Timer_read());
  ReefAngel.LCD.DrawText(DefaultFGColor, DefaultBGColor, 46, 70, "DP2:");
  ReefAngel.LCD.DrawText(DefaultFGColor, DefaultBGColor, 71, 70, InternalMemory.DP2Timer_read());
  ReefAngel.LCD.DrawText(DefaultFGColor, DefaultBGColor, 86, 70, "DP3:");
  ReefAngel.LCD.DrawText(DefaultFGColor, DefaultBGColor, 111, 70, DP3_Timer);
  // draw main relay
  ReefAngel.LCD.DrawOutletBox(12, 87, TempRelay);
#ifdef RelayExp
  // draw 1st expansion relay
  ReefAngel.LCD.DrawOutletBox(12, 100, TempRelay);
#endif  // RelayExp
void ConvertNumToString(char* string, int num, byte decimal)
	char temptxt[3];
	int Temp = num;
	if (Temp==0xFFFF) Temp=0;
		itoa(Temp/decimal,string,10);
	if (decimal>1)
		itoa(Temp%decimal,temptxt,10);
		strcat(string, ".");
		if (Temp%decimal<10 && decimal==100) strcat(string, "0");
			strcat(string, temptxt);
	byte x = 6;
	byte y = 2;
	byte t;
	ReefAngel.LCD.DrawDate(6, 2);
	x = 12;
	y += MENU_START_ROW+4;
	ReefAngel.LCD.DrawSingleMonitor(ReefAngel.PWM.GetDaylightValue(),DPColor, x, y, 1);
	t = intlength(ReefAngel.PWM.GetDaylightValue()) + 1;
	t *= 5;
	ReefAngel.LCD.DrawText(DPColor, DefaultBGColor, x+t, y, "%");
	t += 10;
	x += t;
	ReefAngel.LCD.DrawSingleMonitor(ReefAngel.PWM.GetActinicValue(),APColor, x, y, 1);
	t = intlength(ReefAngel.PWM.GetActinicValue()) + 1;
	t *= 5;
	ReefAngel.LCD.DrawText(APColor, DefaultBGColor, x+t, y, "%");
	t += 10;
	x += t;
	char text[7];
	ReefAngel.LCD.Clear(DefaultBGColor, x+16, y, x+45, y+16);
	ReefAngel.LCD.DrawLargeText(PHColor, DefaultBGColor, x+16, y, text,Font8x16);
	ConvertNumToString(text, ReefAngel.Params.Temp1, 10);
	y += MENU_START_ROW*2;
	x = 10;
	ReefAngel.LCD.Clear(DefaultBGColor,x,y,x+(16*4),y+16);
	ReefAngel.LCD.DrawHugeNumbers(T1TempColor, DefaultBGColor, x, y, text);
	x += (16*4) + 8;
	ReefAngel.LCD.DrawText(T2TempColor,DefaultBGColor,x,y,"T2:");
	ReefAngel.LCD.DrawSingleMonitor(ReefAngel.Params.Temp2, T2TempColor, x+18, y, 10);
	ReefAngel.LCD.DrawText(T3TempColor,DefaultBGColor,x,y+10,"T3:");
	ReefAngel.LCD.DrawSingleMonitor(ReefAngel.Params.Temp3, T3TempColor, x+18, y+10, 10);
	y += 16*2;
	x = 8;
	ReefAngel.LCD.DrawText(DefaultFGColor, DefaultBGColor, x, y, "DP1:");
	ReefAngel.LCD.DrawText(DefaultFGColor, DefaultBGColor, x+25, y, InternalMemory.DP1Timer_read());
	ReefAngel.LCD.DrawText(DefaultFGColor, DefaultBGColor, x+37, y, "DP2:");
	ReefAngel.LCD.DrawText(DefaultFGColor, DefaultBGColor, x+62, y, InternalMemory.DP2Timer_read());
	ReefAngel.LCD.DrawText(DefaultFGColor, DefaultBGColor, x+75, y, "DP3:");
	ReefAngel.LCD.DrawText(DefaultFGColor, DefaultBGColor, x+101, y, DP3_Timer);
        x = 6;
	y += MENU_START_ROW+6;
        y -= 3;
        ReefAngel.LCD.Clear(COLOR_BLACK, x, y, 124, y);
        y +=1;
        ReefAngel.LCD.Clear(COLOR_BLUE, x+1, y, 123, y+10);
        y +=11;
        ReefAngel.LCD.Clear(COLOR_BLACK, x, y-11, x, y+16);
        ReefAngel.LCD.Clear(COLOR_BLACK, 124, y-11, 124, y+16);
        ReefAngel.LCD.DrawText(COLOR_WHITE, COLOR_BLUE, x+40, y-9, "Alarms");
        y += 6;
        x += 2;
	byte fcolor;
	// This is for the LOW Ato switch
	ReefAngel.LCD.DrawText(DefaultFGColor, DefaultBGColor, x+2, y,"ATO:");
	if ( InternalMemory.read(700) == 1 )
		// add in InternalMemory.write(700, 1) when ato is tripped
		// add in InternalMemory.write(700, 0) when ato is cleared
		fcolor = COLOR_RED;
		ReefAngel.LCD.DrawText(fcolor, DefaultBGColor, x+30, y, "YES");
		fcolor = COLOR_GREEN;
		ReefAngel.LCD.DrawText(fcolor, DefaultBGColor, x+30, y, "NO ");
	ReefAngel.LCD.DrawText(DefaultFGColor, DefaultBGColor, x+55, y,"OverH:");
	if ( InternalMemory.read(701) == 1 )
		// add in InternalMemory.write(701, 1) when overheat is tripped
		// add in InternalMemory.write(701, 0) when overheat is cleared
		fcolor = COLOR_RED;
		strcpy(text, "YES");
		strcpy(text, "NO ");
	ReefAngel.LCD.DrawText(fcolor, DefaultBGColor, x+94, y, text);
        ReefAngel.LCD.Clear(COLOR_BLACK, x-2, y+11, 124, y+11);
	x = 12;
	y += 18;
	ReefAngel.LCD.DrawOutletBox(x, y, TempRelay);
 // ReefAngel.LCD.DrawGraph(5,50);
    ReefAngel.SetTemperatureUnit(1);  // set to Celsius Temperature
    ReefAngel.PWM.SetActinic(0);
    ReefAngel.PWM.SetDaylight(0);
    //WifiAuthentication("lukeluke:Luca123");
    // Set the ports that get toggled on & off during the following modes
    // To enable a port to be toggled, place a 1 in the appropriate position
    // Uncomment and update as needed
    // Port 87654321
    ReefAngel.FeedingModePorts = B00000011;
    ReefAngel.WaterChangePorts = B00000011;
    ReefAngel.OverheatShutoffPorts = B00001011;
    //ReefAngel.LightsOnPorts = B00000110;
//    ReefAngel.Relay.On(Port4);  //Turn the Skimmer
    ReefAngel.Relay.On(Port2);
   // ReefAngel.Relay.On(Port1);
    // Specific functions
    ReefAngel.SingleATOHigh(Port6);
    ReefAngel.StandardFan(Port1);
    ReefAngel.StandardHeater(Port8);
    ReefAngel.DelayedOn(Port4,10);
    if (ReefAngel.Params.Temp1 > 290)
        ReefAngel.PWM.SetActinic(PWMSlope(12,15,23,45,0,InternalMemory.LEDPWMActinic_read(),90,ReefAngel.PWM.GetActinicValue()));
        ReefAngel.PWM.SetDaylight(PWMSlope(13,30,22,30,0,40,30,ReefAngel.PWM.GetDaylightValue()));
    else if (ReefAngel.Params.Temp1 > 280)
        ReefAngel.PWM.SetDaylight(PWMSlope(13,30,22,30,0,70,30,ReefAngel.PWM.GetDaylightValue()));
       ReefAngel.PWM.SetDaylight(PWMSlope(13,30,22,30,0,InternalMemory.LEDPWMDaylight_read(),30,ReefAngel.PWM.GetDaylightValue()));
    ReefAngel.DosingPump(Port3, 1, 23, 00, InternalMemory.DP1Timer_read());
    ReefAngel.DosingPump(Port3, 1, 05, 00, InternalMemory.DP1Timer_read());
    ReefAngel.DosingPump(Port3, 1, 11, 00, InternalMemory.DP1Timer_read());
    ReefAngel.DosingPump(Port3, 1, 17, 00, InternalMemory.DP1Timer_read());
    ReefAngel.DosingPump(Port5, 2, 23, 10, InternalMemory.DP2Timer_read());
    ReefAngel.DosingPump(Port5, 2, 05, 10, InternalMemory.DP2Timer_read());
    ReefAngel.DosingPump(Port5, 2, 11, 10, InternalMemory.DP2Timer_read());
    ReefAngel.DosingPump(Port5, 2, 17, 10, InternalMemory.DP2Timer_read());
    ReefAngel.DosingPump(Port7, 4, 23, 20, DP3_Timer); // Setup Dosing Pump 3 Oligo
in the latest i change the PWM because i use the MH now .....
