Add ELSE mode for WP40
Posted: Sun May 04, 2014 8:55 am
Hi
I have a WP40 pump and i want set it in ELSE mode, I make a code with the wizard for the things i need, but i'll to use ELSE mode instead of the ones provided in the wizard i found a code in the Addons section that will work for what i want, but i don't how to add it to the code and how to set the intervals i want, this is my code:
This is the code i find in the addons, made by Cosmith71:
Could some one add that to my code so i can just uploaded to the RA, thanks a lot.
#include <[color=#CC6600]Wire[/color].h>
#include <[color=#CC6600]OneWire[/color].h>
#include <[color=#006699]LED[/color].h>
#include <[color=#006699]Relay[/color].h>
#include <[color=#006699]Timer[/color].h>
#include <[color=#006699]Salinity[/color].h>
#include <[color=#006699]RF[/color].h>
#include <[color=#006699]IO[/color].h>
#include <[color=#006699]ORP[/color].h>
#include <[color=#006699]AI[/color].h>
#include <[color=#006699]PH[/color].h>
#include <[color=#006699]WaterLevel[/color].h>
#include <[color=#006699]Humidity[/color].h>
#include <[color=#006699]DCPump[/color].h>
#include <[color=#CC6600]ReefAngel[/color].h>
[color=#7E7E7E]////// Place global variable code below here[/color]
[color=#7E7E7E]////// Place global variable code above here[/color]
[color=#CC6600]void[/color] [color=#CC6600][b]setup[/b][/color]()
[color=#7E7E7E]// This must be the first line[/color]
[color=#CC6600]ReefAngel[/color].[color=#CC6600]Init[/color](); [color=#7E7E7E]//Initialize controller[/color]
[color=#CC6600]ReefAngel[/color].[color=#CC6600]SetTemperatureUnit[/color]( [color=#006699]Celsius[/color] ); [color=#7E7E7E]// set to Celsius Temperature[/color]
[color=#7E7E7E]// Ports toggled in Feeding Mode[/color]
[color=#CC6600]ReefAngel[/color].[color=#006699]FeedingModePorts[/color] = [color=#006699]Port8Bit[/color];
[color=#7E7E7E]// Ports toggled in Water Change Mode[/color]
[color=#CC6600]ReefAngel[/color].[color=#006699]WaterChangePorts[/color] = [color=#006699]Port1Bit[/color] | [color=#006699]Port7Bit[/color] | [color=#006699]Port8Bit[/color];
[color=#7E7E7E]// Ports toggled when Lights On / Off menu entry selected[/color]
[color=#CC6600]ReefAngel[/color].[color=#006699]LightsOnPorts[/color] = 0;
[color=#7E7E7E]// Ports turned off when Overheat temperature exceeded[/color]
[color=#CC6600]ReefAngel[/color].[color=#006699]OverheatShutoffPorts[/color] = [color=#006699]Port8Bit[/color];
[color=#7E7E7E]// Use T1 probe as temperature and overheat functions[/color]
[color=#CC6600]ReefAngel[/color].[color=#006699]TempProbe[/color] = [color=#006699]T1_PROBE[/color];
[color=#CC6600]ReefAngel[/color].[color=#006699]OverheatProbe[/color] = [color=#006699]T1_PROBE[/color];
[color=#7E7E7E]// Set the Overheat temperature setting[/color]
[color=#CC6600]InternalMemory[/color].[color=#CC6600]OverheatTemp_write[/color]( 300 );
[color=#7E7E7E]// Feeeding and Water Change mode speed[/color]
[color=#CC6600]ReefAngel[/color].[color=#006699]DCPump[/color].[color=#006699]FeedingSpeed[/color]=0;
[color=#CC6600]ReefAngel[/color].[color=#006699]DCPump[/color].[color=#006699]WaterChangeSpeed[/color]=0;
[color=#7E7E7E]// Ports that are always on[/color]
[color=#CC6600]ReefAngel[/color].[color=#006699]Relay[/color].[color=#CC6600]On[/color]( [color=#006699]Port7[/color] );
[color=#CC6600]ReefAngel[/color].[color=#006699]Relay[/color].[color=#CC6600]On[/color]( [color=#006699]Port8[/color] );
[color=#7E7E7E]////// Place additional initialization code below here[/color]
[color=#7E7E7E]////// Place additional initialization code above here[/color]
[color=#CC6600]void[/color] [color=#CC6600][b]loop[/b][/color]()
[color=#CC6600]ReefAngel[/color].[color=#CC6600]StandardATO[/color]( [color=#006699]Port1[/color],600 );
[color=#CC6600]ReefAngel[/color].[color=#CC6600]StandardLights[/color]( [color=#006699]Port2[/color],15,0,22,30 );
[color=#CC6600]ReefAngel[/color].[color=#CC6600]StandardLights[/color]( [color=#006699]Port3[/color],15,30,22,0 );
[color=#CC6600]ReefAngel[/color].[color=#CC6600]MHLights[/color]( [color=#006699]Port4[/color],16,0,21,30,1 );
[color=#CC6600]ReefAngel[/color].[color=#CC6600]StandardLights[/color]( [color=#006699]Port5[/color],10,29,23,0 );
[color=#CC6600]ReefAngel[/color].[color=#CC6600]StandardLights[/color]( [color=#006699]Port6[/color],23,0,11,0 );
[color=#CC6600]ReefAngel[/color].[color=#006699]DCPump[/color].[color=#006699]UseMemory[/color] = [color=#CC6600]false[/color];
[color=#CC6600]ReefAngel[/color].[color=#006699]DCPump[/color].[color=#CC6600]SetMode[/color]( TidalSwell,80,10 );
[color=#CC6600]ReefAngel[/color].[color=#006699]DCPump[/color].[color=#006699]DaylightChannel[/color] = [color=#006699]Sync[/color];
[color=#CC6600]ReefAngel[/color].[color=#006699]DCPump[/color].[color=#006699]ActinicChannel[/color] = [color=#006699]None[/color];
[color=#7E7E7E]////// Place your custom code below here[/color]
[color=#7E7E7E]////// Place your custom code above here[/color]
[color=#7E7E7E]// This should always be the last line[/color]
[color=#CC6600]ReefAngel[/color].[color=#CC6600]Portal[/color]( [color=#006699]"symon_say"[/color] );
[color=#CC6600]ReefAngel[/color].[color=#CC6600]ShowInterface[/color]();
if (WaveSync)
return NewSpeed;
return AntiSpeed;
