RA not controlling kessils
MrCaveman
Post by MrCaveman »
I have 3 A360's, standard RA my relay box was bought as PWM but it has the changeable jumpers and I have changed it to Analog, I have the kessil control cable. Yesterday I wired up the lights and they ramped down fine and turned off. But this morning the lights never turned on. I unplug the control cable and the lights come on but with the cable plugged in they go off. I'm not a tech savvy person so I have no idea what I am doing wrong. I have the dimming set to parabola. And have played with the controller setting the lights to 100% to see if it does anything. Heres my code generated by the wizard #include <ReefAngel_Features.h>
ReefAngel.FeedingModePorts = Port1Bit | Port4Bit | Port5Bit | Port6Bit | Port8Bit;
ReefAngel.WaterChangePorts = Port1Bit | Port4Bit | Port5Bit | Port6Bit | Port8Bit;
ReefAngel.StandardHeater( Port2,766,800 );
ReefAngel.StandardLights( Port3,8,0,23,0 );
ReefAngel.StandardFan( Port4,770,805 );
ReefAngel.PWM.SetDaylight( PWMParabola(11,0,21,0,1,70,1) );
ReefAngel.PWM.SetActinic( PWMParabola(10,0,22,0,1,75,1) );
Re: RA not controlling kessils
What does the channels say on the screen for actinic and daylight?
MrCaveman
Post by MrCaveman »
I got home from work and the lights were on so the RA is controlling them so I guess i need to play with it a bit more. Is there a minimum percent for the lights to turn on? When I left I believe Daylights said 1 and actinics were at 13. I got home and daylight was 69 and actinic was 75. Also noted that the time on the controller hasnt been adjusted to the current time yet so Im guessing that the light time cycle was thrown off course from what I expected and that the chanels hadn't hit the minimum yet if there is one.
I think it is 10%
