Dimming expansion q
pandimus
Dimming expansion q
How do I make channels of my dimming expansion act like actinic, instead of daylights?
Re: Dimming expansion q
There is nothing that says daylight or actinic on the dimming expansion. You connect and use each channel at will.
pandimus
For time, they currently turn on with daylights
You can choose which time each channel is supposed to turn on.
Or are you using internal memory?
pandimus
You can add an offset after the value you are using.
ReefAngel.PWM.Channel0PWMSlope(30); // Starts 30 minutes earlier and ends 30 minutes later
pandimus
