Dimming expansion q
Posted: Mon May 19, 2014 12:50 am
by pandimus
How do I make channels of my dimming expansion act like actinic, instead of daylights?
Re: Dimming expansion q
Posted: Mon May 19, 2014 7:32 am
There is nothing that says daylight or actinic on the dimming expansion. You connect and use each channel at will.
Posted: Mon May 19, 2014 7:37 am
by pandimus
For time, they currently turn on with daylights
Posted: Mon May 19, 2014 7:39 am
You can choose which time each channel is supposed to turn on.
Or are you using internal memory?
Posted: Mon May 19, 2014 8:53 am
by pandimus
Internal
Posted: Mon May 19, 2014 7:17 pm
You can add an offset after the value you are using.
ReefAngel.PWM.Channel0PWMSlope(30); // Starts 30 minutes earlier and ends 30 minutes later
Posted: Mon May 19, 2014 7:40 pm
by pandimus
thanks roberto
