Relay expansion daylight channel question
ritorres
Post by ritorres »
Hi, i have a question, I have the main relay and one expansion, then I have 2 daylight channel and 2 actinic channel, can i use all channel for 4 wavemakers?
Enviado desde mi SM-T310 mediante Tapatalk
Re: Relay expansion daylight channel question
The dimming ports on the expansion relay are not operational, just the ones one the original relay will work.
ritorres
Post by ritorres »
Oh, so bad, thanks :)
Your ATO switch ports can be used if they are not already. You could replace the float switches with water level sensor. You will need modified Jaebo cables to handle 5v. Assuming you have the RA+ otherwise you can only use the Low port.
ritorres
Post by ritorres »
I will test :) thanks
