How can I make this fit?
Posted: Sun May 25, 2014 12:23 pm
by morn623
I just have an RA and not an RA+. I was wondering if there was any way to make the following code fit?
[code#include <ReefAngel_Features.h>
ReefAngel.FeedingModePorts = Port1Bit;
ReefAngel.OverheatShutoffPorts = Port3Bit;
InternalMemory.OverheatTemp_write( 1000 );
ReefAngel.Relay.On( Port4 );
ReefAngel.StandardLights( Port2,20,0,8,0 );
ReefAngel.StandardHeater( Port3,760,780 );
ReefAngel.CO2Control( Port6,810,840 );
ReefAngel.StandardLights( Port7,8,0,20,0 );
ReefAngel.PWM.SetChannel( 0, PWMParabola(8,0,20,0,0,80,0) );
ReefAngel.PWM.SetChannel( 1, PWMParabola(8,0,20,0,0,80,0) );
ReefAngel.PWM.SetChannel( 2, PWMParabola(8,0,20,0,0,80,0) );
ReefAngel.Portal( "morn623" );
int x,y;
// Dimming Expansion
x = 15;
y = 2;
for ( int a=0;a<6;a++ )
if ( a>2 ) x = 75;
if ( a==3 ) y = 2;
y += 10;
// Parameters
// Main Relay Box
// Date and Time
][/code]
If this can't be made to fit, I have two questions...
Is there any way to just upgrade the memory on the RA without getting the board upgrade?
If not, does anyone know if the old LCD screen is compatible with the board upgrade?
Re: How can I make this fit?
Posted: Sun May 25, 2014 1:16 pm
by pandimus
There's no way to just upgrade memory, as it's part of the processor. The lcd will work fine. Just swap out board. As for the coding. Ill wait for the pros to speak up
Posted: Sun May 25, 2014 2:49 pm
what version of the libraries are you using? you may have to downgrade to and older version of the libraries to make it fit. version 1.1.0 is large and i am not sure if it can still fit on a standard controller. you may want to try 1.0.9 or even lower to make it fit. others may have additional input.
Posted: Sun May 25, 2014 6:25 pm
by morn623
Where can I find the older libraries?
Posted: Sun May 25, 2014 6:41 pm
morn623 wrote:Where can I find the older libraries?
they are located on github.
https://github.com/reefangel/Libraries
you can download the older releases and test them out.
Sent from my Moto X
