Problem upgrading to RA+
symon_say
Post by symon_say »
Hi
I just install the RA+ board, but i just get a black screen, it powers but shows anything, and when i try to upload anything to it i get this on arduino:
avrdude: Version 6.0, compiled on Apr  6 2012 at 19:29:19
         Using Port                    : \\.\COM4
         Using Programmer              : stk500v2
         Overriding Baud Rate          : 115200
avrdude: Send: . [1b] . [01] . [00] . [01] . [0e] . [01] . [14]
avrdude: Recv:
avrdude done.  Thank you.
I test the cable with the wifi and it comunicates perfectly, it even update the firmware, but RA+ don't seen to work.
howaboutme
Re: Problem upgrading to RA+
Post by howaboutme »
Try this...usually it's a white screen..worth a shot:
http://forum.reefangel.com/viewtopic.ph ... een#p35423
I had the same problem when upgrading boards.
Jack
symon_say
Post by symon_say »
howaboutme wrote:Try this...usually it's a white screen..worth a shot:
Thanks, I found your post, but i can't upload any codes to the RA+, arduino is not communicating with RA.
You are sure that the com port is COM4, right?
Are you able to upload to the old RA on the same COM4 port?
symon_say
Post by symon_say »
rimai wrote:You are sure that the com port is COM4, right?
Yes, everything thing to work, except i can't upload codes to RA+, wifi is detected and updated, RA client connect to RA+ but Arduino gives me that error.
And the screen is black with a white line in the center on RA+ but works fine on RA.
You must shutdown the RA Client service. It is probably not letting you open the port.
The link above will take care of the screen.
symon_say
Post by symon_say »
rimai wrote:You must shutdown the RA Client service. It is probably not letting you open the port.
RA client is shut down, i even uninstall it, in case it was giving the problem.
Its the service not the client. You need to go into Services app to close it.
symon_say
Post by symon_say »
lnevo wrote:Its the service not the client. You need to go into Services app to close it.
Thanks, I went into services and stop then all, still the same error.
Can you upload codes correctly on your old RA using the same com4 port?
symon_say
Post by symon_say »
rimai wrote:Can you upload codes correctly on your old RA using the same com4 port?
Yes.
howaboutme
Did you pick Reef Angel Plus Controller (as opposed to your old RA) in the Arduino? I forgot where exactly it is and I don't have the installer on my current computer.
Jack
symon_say
Post by symon_say »
howaboutme wrote:Did you pick Reef Angel Plus Controller (as opposed to your old RA) in the Arduino? I forgot where exactly it is and I don't have the installer on my current computer.
Yes, i did.
It is in Tools/Board...
Is it a new board? Were you ever able to upload codes to it before?
symon_say
Post by symon_say »
rimai wrote:Is it a new board? Were you ever able to upload codes to it before?
Its a new board, never used before.
I test everyone of them before shipment.
Something may have damaged the programming port then.
You will need to send it back.
PM me for RMA.
