Problem upgrading to RA+
Posted: Sun Jun 01, 2014 6:36 am
by symon_say
Hi
I just install the RA+ board, but i just get a black screen, it powers but shows anything, and when i try to upload anything to it i get this on arduino:
avrdude: Version 6.0, compiled on Apr  6 2012 at 19:29:19
         Using Port                    : \\.\COM4
         Using Programmer              : stk500v2
         Overriding Baud Rate          : 115200
avrdude: Recv:
avrdude done.  Thank you.
I test the cable with the wifi and it comunicates perfectly, it even update the firmware, but RA+ don't seen to work.
Re: Problem upgrading to RA+
Posted: Sun Jun 01, 2014 7:44 am
by howaboutme
Try this...usually it's a white screen..worth a shot:
http://forum.reefangel.com/viewtopic.ph ... een#p35423
I had the same problem when upgrading boards.
Posted: Sun Jun 01, 2014 8:00 am
by symon_say
howaboutme wrote:Try this...usually it's a white screen..worth a shot:
Thanks, I found your post, but i can't upload any codes to the RA+, arduino is not communicating with RA.
Posted: Sun Jun 01, 2014 9:13 am
You are sure that the com port is COM4, right?
Are you able to upload to the old RA on the same COM4 port?
Posted: Sun Jun 01, 2014 1:20 pm
by symon_say
rimai wrote:You are sure that the com port is COM4, right?
Yes, everything thing to work, except i can't upload codes to RA+, wifi is detected and updated, RA client connect to RA+ but Arduino gives me that error.
And the screen is black with a white line in the center on RA+ but works fine on RA.
Posted: Sun Jun 01, 2014 1:28 pm
You must shutdown the RA Client service. It is probably not letting you open the port.
The link above will take care of the screen.
Posted: Sun Jun 01, 2014 2:12 pm
by symon_say
rimai wrote:You must shutdown the RA Client service. It is probably not letting you open the port.
RA client is shut down, i even uninstall it, in case it was giving the problem.
Posted: Sun Jun 01, 2014 2:20 pm
Its the service not the client. You need to go into Services app to close it.
Posted: Sun Jun 01, 2014 2:43 pm
by symon_say
lnevo wrote:Its the service not the client. You need to go into Services app to close it.
Thanks, I went into services and stop then all, still the same error.
Posted: Sun Jun 01, 2014 8:22 pm
Can you upload codes correctly on your old RA using the same com4 port?
Posted: Mon Jun 02, 2014 5:54 am
by symon_say
rimai wrote:Can you upload codes correctly on your old RA using the same com4 port?
Yes.
Posted: Mon Jun 02, 2014 7:33 am
by howaboutme
Did you pick Reef Angel Plus Controller (as opposed to your old RA) in the Arduino? I forgot where exactly it is and I don't have the installer on my current computer.
Posted: Mon Jun 02, 2014 11:11 am
by symon_say
howaboutme wrote:Did you pick Reef Angel Plus Controller (as opposed to your old RA) in the Arduino? I forgot where exactly it is and I don't have the installer on my current computer.
Yes, i did.
It is in Tools/Board...
Posted: Mon Jun 02, 2014 3:38 pm
Is it a new board? Were you ever able to upload codes to it before?
Posted: Mon Jun 02, 2014 5:39 pm
by symon_say
rimai wrote:Is it a new board? Were you ever able to upload codes to it before?
Its a new board, never used before.
Posted: Mon Jun 02, 2014 5:55 pm
I test everyone of them before shipment.
Something may have damaged the programming port then.
You will need to send it back.
PM me for RMA.
