using ph 4 and ph 7 calibration fluid
Posted: Wed Jun 11, 2014 9:57 am
by villanbanga
hi
i am in the process of buy a RA and have been told that I can calibrate ph with ph 4 and ph 7 fluid
"I could only find you 4 and 7 calibration fluid. This fluid will work with a slight adjustment to the code"
is this true and how would I go about doing this
Re: using ph 4 and ph 7 calibration fluid
Posted: Wed Jun 11, 2014 12:50 pm
If you add this to your code, you can calibrate with 4 and 7:
Posted: Wed Jun 11, 2014 12:51 pm
by howaboutme
villanbanga wrote:hi
Regardless of that, you want to calibrate close to the numbers are tanks run at, which is using 7 and 10. It's readily available at all of the online stores.
Posted: Thu Jun 12, 2014 11:04 am
by villanbanga
rimai wrote:If you add this to your code, you can calibrate with 4 and 7:
thanks will try it as soon as I receive my RA. Cant wait
Posted: Thu Jun 12, 2014 11:14 am
by villanbanga
Regardless of that, you want to calibrate close to the numbers are tanks run at, which is using 7 and 10. It's readily available at all of the online stores.[/quote]
well should I use sea water then? the problem is I live in Mozambique ( in Africa) my closest LFS is in another country, and they only have 7 & 4 so I take what I can get ( nearest post office 250 km)
thanks for the info
Posted: Thu Jun 12, 2014 11:58 am
by howaboutme
villanbanga wrote:Regardless of that, you want to calibrate close to the numbers are tanks run at, which is using 7 and 10. It's readily available at all of the online stores.
thanks for the info
ah..did not realize you lived there. In that case, 4 and 7 is fine.
