first step with RA
Posted: Fri Jun 13, 2014 3:15 am
by hawaiiensis38
Hello
Sorry, i'm new and have the simply RA controler
I have some question
How many led Chanel can i plug with the RA
How many expansion i need to use my DIY LED light?
i have 3 DIY Cree LED light
On each led light
- Chanel 1 12 x XML cool white
- Chanel 2 12 x Royal blue
- Chanel 3 14 x Blue
I hope it it's clear for you I'm from France
Regards
Hawaii
Re: first step with RA
Posted: Fri Jun 13, 2014 8:36 am
The base controller has 2 dimming ports.
You can plug multiple LED drivers to each dimming port.
Posted: Fri Jun 13, 2014 8:53 am
by Sacohen
As Roberto said the basic RA+ has 2 dimming ports.
If you want all 3 channels controlled separately then you will need the dimming module for the extra channel or the Blue and Royal Blue channels can be combined to 1 channel if they will be running the same percentages and everything.
Dimming can also be done thru the 2 ATO ports with the proper coding.
Posted: Fri Jun 13, 2014 9:37 am
by hawaiiensis38
Hello
Thanks for the reply
can i complete my question?
3 led light separates
each one with
- 3 x 12 Cree XML cool white
- 3 x 12 Cree Royal Blue
- 3 x 14 Cree Blue
- 6 Mean Well ELN-60-48P dimmable driver
- 1 Mean Well HLG-185-42B dimmable Driver for the royal blue in parallel
need i an expansion dimming ?
- Sacohen i can run the royal blue and the Blue on one Chanel
so, i don't need a dimming module, exact?
Or, it it's better to buy one?
Regards
Olivier
Posted: Fri Jun 13, 2014 9:49 am
You can connect them all to the same dimming port.
I would go with the expansion module myself, just to have the ability to split those channels better. You can even think about getting separate dimming in each of your 3 fixtures to create a east to west effect.
Posted: Sat Jun 14, 2014 7:16 am
by hawaiiensis38
Ok thanks Rimai
Olivier
Posted: Sat Jun 14, 2014 8:18 am
by hawaiiensis38
so, i can use my dimming expansion to connect the led light
hawaii
Posted: Sat Jun 14, 2014 8:23 am
by Sacohen
Yes. The dimming modules have 6 ports, so you can control 6 lights or DC pumps or moonlights.
