Hello, After using the RA+ wizard, I have my two WP40s working pretty well. However, I really want to be able to change programs throughout the day. After reading several threads and using the wizard to generate the bulk of the code I have came up with this. Does it look ok? I wasn't sure if you can have a { inside another { or if I should add a } just before the "////// Place your custom code below here" . Thanks!!! Matt
ReefAngel.StandardATO( Port1,7200 );
ReefAngel.StandardLights( Port2,22,0,10,0 );
ReefAngel.StandardLights( Port3,11,0,22,15 );
ReefAngel.StandardLights( Port4,12,0,22,0 );
ReefAngel.StandardHeater( Port7,770,780 );
if (hour()>=0 && hour()<10)
ReefAngel.PWM.SetDaylight( ElseMode(50,30,true) ); // Else on sync mode
ReefAngel.PWM.SetActinic( ElseMode(50,30,true) ); // Else on sync mode
else if (hour()>=10 && hour()<13
ReefAngel.PWM.SetDaylight( NutrientTransportMode(77,90,3000,true) ); // Nutrient Transport on sync mode
ReefAngel.PWM.SetActinic( NutrientTransportMode(77,90,3000,true) ); // Nutrient Transport on sync mode
else if (hour()>=13 && hour()<22
ReefAngel.PWM.SetDaylight( ShortPulseMode(0,80,800,true) ); // Short pulse at 80% with 800ms pulse on sync mode
ReefAngel.PWM.SetActinic( ShortPulseMode(0,80,800,true) ); // Short pulse at 80% with 800ms pulse on sync mode
ReefAngel.DCPump.SetMode( Lagoon,40,70 ); // lagoon at 40% hours 22-24 on sync generated by wizard
DC wavemaker code check
Re: DC wavemaker code check
These 2 lines are missing the closing ).
You can have nested { (curly braces). You just need to close everything up properly and pair up the left braces or parenthesis with right braces or parenthesis.
The above statements should be closed off like this:
else if (hour()>=10 && hour()<13)
else if (hour()>=13 && hour()<22)
Your code should be:
I read the code as from midnight to 10a, do one thing, then from 10a to 1p, do another thing, then from 1p to 10p, do another thing and then from 10p to midnight, do something else.
I did not confirm the commands for the daylight but everything looks syntactically correct. Maybe others will chime in on the correctness of the code.
Otherwise, it looks like you are on the right start except for those 2 missing right parenthesis that I corrected for you.
Thanks! You read it how I was hoping it would go. The pumps are moving. I don't know if they are doing what I want them to but they are moving
Matt
Matt
OK, so after I uploaded the program is seemed to run through everything great the first day, but then just seemed to stay on the last stage and not start over again the next day. Any Idea? Instead of just an else at the end to I need to specify the specific time? Here is the full code I used.
ReefAngel.FeedingModePorts = Port1Bit | Port5Bit | Port6Bit | Port8Bit;
ReefAngel.WaterChangePorts = Port1Bit | Port5Bit | Port6Bit | Port7Bit | Port8Bit;
ReefAngel.OverheatShutoffPorts = Port2Bit | Port3Bit | Port4Bit | Port7Bit;
ReefAngel.Relay.On( Port5 );
if (hour()>=0 && hour()<5)
ReefAngel.PWM.SetDaylight( ElseMode(40,20,true) ); // Else on sync mode
ReefAngel.PWM.SetActinic( ElseMode(40,20,false) ); // Else on anti-sync mode
else if (hour()>=5 && hour()<10)
ReefAngel.PWM.SetActinic( ElseMode(50,30,false) ); // Else on anti-sync mode
ReefAngel.PWM.SetDaylight( ShortPulseMode(0,90,800,true) ); // Short pulse at 90% with 800ms pulse on sync mode
ReefAngel.PWM.SetActinic( ShortPulseMode(0,90,800,true) ); // Short pulse at 90% with 800ms pulse on sync mode
if (WaveSync)
return NewSpeed;
return AntiSpeed;
Still can't get it figured out. It will run through the program but not repeat the next day. Any one have any ideas. Thanks!
Try changing this:
to this:
I have similar code if you click on my link below.
if (hour()>=0 || hour()<5)
Jack
