DC wavemaker code check
Posted: Fri Jun 13, 2014 8:43 pm
by Docstach
Hello, After using the RA+ wizard, I have my two WP40s working pretty well. However, I really want to be able to change programs throughout the day. After reading several threads and using the wizard to generate the bulk of the code I have came up with this. Does it look ok? I wasn't sure if you can have a { inside another { or if I should add a } just before the "////// Place your custom code below here" . Thanks!!! Matt
ReefAngel.StandardATO( Port1,7200 );
ReefAngel.StandardLights( Port2,22,0,10,0 );
ReefAngel.StandardLights( Port3,11,0,22,15 );
ReefAngel.StandardLights( Port4,12,0,22,0 );
ReefAngel.StandardHeater( Port7,770,780 );
if (hour()>=0 && hour()<10)
ReefAngel.PWM.SetDaylight( ElseMode(50,30,true) ); // Else on sync mode
ReefAngel.PWM.SetActinic( ElseMode(50,30,true) ); // Else on sync mode
else if (hour()>=10 && hour()<13
ReefAngel.PWM.SetDaylight( NutrientTransportMode(77,90,3000,true) ); // Nutrient Transport on sync mode
ReefAngel.PWM.SetActinic( NutrientTransportMode(77,90,3000,true) ); // Nutrient Transport on sync mode
else if (hour()>=13 && hour()<22
ReefAngel.PWM.SetDaylight( ShortPulseMode(0,80,800,true) ); // Short pulse at 80% with 800ms pulse on sync mode
ReefAngel.PWM.SetActinic( ShortPulseMode(0,80,800,true) ); // Short pulse at 80% with 800ms pulse on sync mode
ReefAngel.DCPump.SetMode( Lagoon,40,70 ); // lagoon at 40% hours 22-24 on sync generated by wizard
Re: DC wavemaker code check
Posted: Fri Jun 13, 2014 8:50 pm
These 2 lines are missing the closing ).
You can have nested { (curly braces). You just need to close everything up properly and pair up the left braces or parenthesis with right braces or parenthesis.
The above statements should be closed off like this:
else if (hour()>=10 && hour()<13)
else if (hour()>=13 && hour()<22)
Your code should be:
I read the code as from midnight to 10a, do one thing, then from 10a to 1p, do another thing, then from 1p to 10p, do another thing and then from 10p to midnight, do something else.
I did not confirm the commands for the daylight but everything looks syntactically correct. Maybe others will chime in on the correctness of the code.
Otherwise, it looks like you are on the right start except for those 2 missing right parenthesis that I corrected for you.
Posted: Fri Jun 13, 2014 10:14 pm
by Docstach
Thanks! You read it how I was hoping it would go. The pumps are moving. I don't know if they are doing what I want them to but they are moving
Matt
Posted: Mon Jun 16, 2014 6:54 am
by Docstach
OK, so after I uploaded the program is seemed to run through everything great the first day, but then just seemed to stay on the last stage and not start over again the next day. Any Idea? Instead of just an else at the end to I need to specify the specific time? Here is the full code I used.
ReefAngel.FeedingModePorts = Port1Bit | Port5Bit | Port6Bit | Port8Bit;
ReefAngel.WaterChangePorts = Port1Bit | Port5Bit | Port6Bit | Port7Bit | Port8Bit;
ReefAngel.OverheatShutoffPorts = Port2Bit | Port3Bit | Port4Bit | Port7Bit;
if (hour()>=0 && hour()<5)
ReefAngel.PWM.SetDaylight( ElseMode(40,20,true) ); // Else on sync mode
ReefAngel.PWM.SetActinic( ElseMode(40,20,false) ); // Else on anti-sync mode
else if (hour()>=5 && hour()<10)
ReefAngel.PWM.SetActinic( ElseMode(50,30,false) ); // Else on anti-sync mode
ReefAngel.PWM.SetDaylight( ShortPulseMode(0,90,800,true) ); // Short pulse at 90% with 800ms pulse on sync mode
ReefAngel.PWM.SetActinic( ShortPulseMode(0,90,800,true) ); // Short pulse at 90% with 800ms pulse on sync mode
static unsigned long LastChange=millis(); // Set the inital time that the last change occurred
static int Delay = random( 500, 3000); // Set the initial delay
static int NewSpeed = MidPoint; // Set the initial speed
static int AntiSpeed = MidPoint; // Set the initial anti sync speed
if ((millis()-LastChange) > Delay) // Check if the delay has elapsed
Delay=random(500,5000); // If so, come up with a new delay
int ChangeUp = random(Offset); // Amount to go up or down
if (random(100)<50) // 50/50 chance of speed going up or going down
LastChange=millis(); // Reset the time of the last change
if (WaveSync)
return NewSpeed;
return AntiSpeed;
Posted: Fri Jun 20, 2014 10:26 pm
by Docstach
Still can't get it figured out. It will run through the program but not repeat the next day. Any one have any ideas. Thanks!
Posted: Sat Jun 21, 2014 5:25 am
by howaboutme
Try changing this:
to this:
I have similar code if you click on my link below.
