I've downloaded a few times and tried over and over to get the Wifi utility working on my Mac. When I click on the wifi utility is says that the file is damaged and cannot be opened. I've deleted it and redownloaded/reinstalled with the same results.
I'm trying to set up an RA with wifi that I picked up locally used. I've connect the RA to Arduino and run some basic stuff with the wizard, but for the life of me cannot get this wifi going.
Any ideas?
Wifi Utility
Re: Wifi Utility
What is damaged? The disk image that you download from the website or the wifi utility inside the disk image?
Re: Wifi Utility
I'm assuming the wifi utility.
....so now I'm trying to do it all through Arduino and I'm new to all of that....sooooo....it's not going to well! lol
Re: Wifi Utility
Can you open the disk image?
If so, drag the wifi utility to your desktop.
Then, double-click to run it. Did it work?
Re: Wifi Utility
No I can't. When I double click it it says, "Wifi_Utility" is damaged and can't be opened. You should move it to the trash.
Re: Wifi Utility
This may be related to your security settings on your mac.
Take a look at this article related to Minekeeper that gives a pretty good rundown.
http://gaming.stackexchange.com/questio ... -the-trash
http://support.apple.com/kb/ht5290
Re: Wifi Utility
I tried both of those links listed above and it still says the same thing. No change.
Re: Wifi Utility
Try a different image:
http://download.reefangel.com/download/ ... _1.0.9.dmg
Re: Wifi Utility
Thanks. I'll give that a try when I get home from work!rimai wrote:Try a different image:
