No control
Posted: Sun Jun 29, 2014 7:09 pm
by Cromanon
Hello, today I lost communication from the application of my phone and try by the RA I realize that does not turn the display, disconnect the AC RA for 10 minutes but no change. Can you help me? Thank you.
Re: No control
Posted: Sun Jun 29, 2014 7:43 pm
Is the green power LED lit?
Do you get 3 blinks on the red status led when you apply power?
Re: No control
Posted: Sun Jun 29, 2014 8:56 pm
by Cromanon
Yes when plug on power 3 time on red led and steady on green led
Re: No control
Posted: Sun Jun 29, 2014 8:57 pm
Try uploading any code to it.
What happens?
Re: No control
Posted: Sun Jun 29, 2014 9:08 pm
by Cromanon
No change. Blink red led when upload but display is off and no comunication with app.
Re: No control
Posted: Sun Jun 29, 2014 9:11 pm
Yes, but the code was uploaded correctly, right?
Re: No control
by Cromanon
Yes
Re: No control
Posted: Sun Jun 29, 2014 9:13 pm
Maybe just a bad screen?
Is your wifi attachment blinking blue?
Re: No control
Posted: Sun Jun 29, 2014 9:14 pm
by Cromanon
Just blink first led from left to right
Re: No control
Posted: Sun Jun 29, 2014 9:31 pm
Can you post the code you are uploading?
Re: No control
Posted: Mon Jun 30, 2014 5:31 am
by Cromanon
ReefAngel.FeedingModePorts = Port5Bit | Port6Bit | Port7Bit;
ReefAngel.WaterChangePorts = Port4Bit | Port5Bit | Port6Bit | Port7Bit | Port8Bit;
ReefAngel.OverheatShutoffPorts = Port2Bit | Port3Bit | Port4Bit | Port5Bit | Port6Bit;
ReefAngel.Relay.On( Port4 );
ReefAngel.StandardLights( Port1,11,0,23,0 );
ReefAngel.StandardLights( Port2,12,0,16,0 );
ReefAngel.StandardLights( Port3,20,0,10,0 );
ReefAngel.Relay.DelayedOn( Port6,4 );
ReefAngel.Relay.DelayedOn( Port7,2 );
ReefAngel.SingleATO( true,Port8,240,0 );
ReefAngel.Portal( "cromanon" );
Re: No control
by Cromanon
Re: No control
Posted: Mon Jun 30, 2014 5:55 am
by Cromanon
just for second check, I reenter the ssid and pass in wifi , but no change.
Re: No control
Posted: Mon Jun 30, 2014 8:08 am
Green blink on the wifi attachment means it is connected, so I don't think it's that.
It is sounding like head unit issue.
Is the controller switching relays on/off and just not responding to wifi or you don't hear it click relays at all?
Test it with your ATO float switch. Move it up and down. Does Port8 turn on/off?
Re: No control
Posted: Mon Jun 30, 2014 9:17 am
by Cromanon
yes, I move float sw and sound a click.
Re: No control
by Cromanon
and turn on/off
Re: No control
Posted: Mon Jun 30, 2014 9:20 am
So, it seems the controller is operational and just the screen is malfunctioning, but the wifi should work too.
I'd check for water damage.
Re: No control
Posted: Mon Jun 30, 2014 9:31 am
by Cromanon
ok
Re: No control
Posted: Mon Jun 30, 2014 9:32 am
by Cromanon
Thanks !!!
