Library won't upgrade from 1.0.9
caliman
Hi all -
I am stuck on library 1.0.9 and can't upgrade.
When it tries to auto update it errors out.
When I verify/compile, I get this:
Watchdog Timer
Version Menu
Simple Menu
core.a(main.cpp.o): In function `main':
/Applications/Arduino.app/Contents/Resources/Java/hardware/arduino/cores/arduino/main.cpp:5: undefined reference to `setup'
/Applications/Arduino.app/Contents/Resources/Java/hardware/arduino/cores/arduino/main.cpp:15: undefined reference to `loop'
Please advise. Thanks in advance!
My reef angel doesn't chart anymore. I think it is related. There is also an error on the screen that says PHE: ERROR
Watchdog Timer
Version Menu
Simple Menu
Re: Library won't upgrade from 1.0.9
There is an auto-update feature that should have kept you up to date.
Please check menu File->Preferences.
Do you have a checkmark under "Check for updates on startup" ?
That error is generated when you try to compile an empty code.
Make sure you go through the wizard before compiling/uploading a code or post the code you are trying to upload so we can see what is going on.
PHE is for pH expansion module. If the module is disconnected or if you don't have one, it will show error.
caliman
Hi Roberto -
I do get that error when it checks on startup.
Thanks for info on the PHE error.
Here is my code (I generated this from the wizard):
ReefAngel.WaterChangePorts = Port1Bit | Port2Bit | Port5Bit | Port6Bit | Port8Bit;
ReefAngel.OverheatShutoffPorts = Port3Bit | Port4Bit | Port7Bit;
ReefAngel.Relay.On( Port5 );
ReefAngel.Relay.On( Port7 );
ReefAngel.MoonLights( Port2 );
ReefAngel.ActinicLights( Port3 );
ReefAngel.DayLights( Port4 );
ReefAngel.RF.UseMemory = true;
ReefAngel.Portal( "caliman", "498y" );
int x,y;
ReefAngel.LCD.DrawMonitor( 15, 14, ReefAngel.Params,
ReefAngel.LCD.DrawMonitor( 15, 14, ReefAngel.Params );
// ORP
ReefAngel.LCD.DrawText( COLOR_PALEVIOLETRED,DefaultBGColor,49,54, "ORP:" );
ReefAngel.LCD.DrawText( COLOR_PALEVIOLETRED,DefaultBGColor,73,54, ReefAngel.Params.ORP );
// pH Expansion
ReefAngel.LCD.DrawText( COLOR_MEDIUMSEAGREEN,DefaultBGColor,15,75, "PHE:" );
ReefAngel.LCD.DrawSingleMonitor( ReefAngel.Params.PHExp,COLOR_MEDIUMSEAGREEN,39,75, 100 );
ReefAngel.LCD.DrawOutletBox( 12, 95, TempRelay );
You should get that only when you compile not when you open Arduino.
Your code looks fine.
Here is what I suggest then.
Go to your Documents folder and rename the folder Arduino to ArduinoOld.
Then, download the latest Installer from the website and install it again.
caliman
I actually did install new from the site and still have this issue.
If you installed from the website, it should be 1.1.0
Did you rename the Arduino folder prior to reinstall?
caliman
Odd. I did not rename but chose 'keep both.' I will look into this some more and report back.
caliman
I have some more info for you.
I opened another copy of Arduinio on my computer - it asked if I wanted to upgrade to the latest library and I said yes... it went all the way to 100% progress and crashed here:
Updating /libraries/NokiaLCD/README
Updating /libraries/OneWire/keywords.txt
Updating /libraries/OneWire/OneWire.cpp
java.io.IOException: Server returned HTTP response code: 503 for URL: https://raw.github.com/reefangel/libraries/master/OneWire/OneWire.cpp
at sun.net.www.protocol.http.HttpURLConnection.getInputStream(HttpURLConnection.java:1459)
at sun.net.www.protocol.https.HttpsURLConnectionImpl.getInputStream(HttpsURLConnectionImpl.java:234)
at java.net.URL.openStream(URL.java:1010)
at processing.app.UpdateCheck$DownloadFile.copyURLtoFile(UpdateCheck.java:274)
at processing.app.UpdateCheck$DownloadFile.run(UpdateCheck.java:243)
at java.lang.Thread.run(Thread.java:695)
Exception in thread "Thread-7" java.lang.NullPointerException
at sun.nio.ch.FileChannelImpl.transferFrom(FileChannelImpl.java:581)
at processing.app.UpdateCheck$DownloadFile.copyURLtoFile(UpdateCheck.java:287)
at java.lang.Thread.run(Thread.java:695)You do not have the required permissions to view the files attached to this post.
I'm not sure what is going on with your update
So, to make it easy for you, download the attached file. It's the latest libraries.
Delete your current folder Documents\Arduino\libraries
Decompress and move the folder libraries to the folder Documents\Arduino
That should put you in the latest libs.
caliman
Thank you Roberto. That made it easy.
I am on 1.1 now.
A while ago one of my updates killed the RA head from graphing.... perhaps this might fix that? You said my code looked good, so I am trying to figure that out a bit. I'll start another thread if need be.
Thanks again!
I am on 1.1 now.
Thanks again!
