Page 1 of 2
Web server basic authentication
Posted: Wed Jul 09, 2014 10:22 am
Hi Guys,
I've added HTTP basic authentication to the webserver.
We failed to implement this in the past, but I think it should be stable this time.
It is currently in the dev branch.
This is the github issue: https://github.com/reefangel/Libraries/issues/154
If you get to test it, please post back here or log it into the github issue tracking whether it worked for you or not.
One point to remind is that your phone app will not work if you enable authentication.
Re: Web server basic authentication
Posted: Wed Jul 09, 2014 11:14 am
what version of libraries will this be added? 1.11? or something or later?
Sent from my Moto X
Posted: Wed Jul 09, 2014 3:39 pm
Yes, it will be available in the next one.
Posted: Wed Jul 09, 2014 6:23 pm
The webserver authentication only works on the controller, correct?
This is not the same as the security key that is used for the portal....ie. ReefAngel.Portal(username, password)
Is that correct?
Then, using this authentication, you would use this url to communicate with your controller:
http://user:pass@DEVICE_IP:PORT/
Hopefully I'm following correctly. Provided I am, I was going to implement this into my android app for those that wanted to test it out and use it.
Posted: Wed Jul 09, 2014 7:17 pm
Yes, it is just basic authentication in the internal RA webserver and sending the url like you mentioned should work, although IE had problems understanding it for some reason, but firefox worked fine with an url like that.
Posted: Wed Jul 09, 2014 7:22 pm
ok. good to know.
i'm going to add this in (doesn't look the best, but works for now).
and then allow people to test things out to see how well it works.
Posted: Wed Jul 09, 2014 8:36 pm
Ok. I've got a working build for the webserver authentication. I'm going to sleep on it and verify things are working properly before I release it tomorrow. I have tested it on my controller at my desk and it works just fine communicating with a v1.1.0 controller with or without the authentication set. I am interested to see / hear how it works when the authentication is actually enabled. I may have to update my errors appropriately because I am not doing anything special for the authentication errors.
Posted: Thu Jul 10, 2014 9:34 am
just posted a beta release of my app that should incorporate the authentication. check my thread for a link to download it.
Posted: Thu Jul 10, 2014 9:42 am
by Smotz
this is awesome! you guys freaking rock!
Posted: Thu Jul 10, 2014 9:43 am
Smotz wrote:this is awesome! you guys freaking rock!
thanks. i decided i would try to stay up on things if i could. :)
Posted: Sun Aug 31, 2014 10:36 am
by Smotz
Sorry but I am not getting it...how do I enable authentication on my RA webpage?
Posted: Sun Aug 31, 2014 3:48 pm
Smotz wrote:Sorry but I am not getting it...how do I enable authentication on my RA webpage?
You need to grab the latest copy of the libraries from the DEV branch. Then you must add this to your setup() of your INO.
ReefAngel.Network.WifiAuthentication("username:password");
Then, that will require that username and password combination to access your controller through the web page.
So you could do:
ReefAngel.Network.WifiAuthentication("myuser:pass4321");
Or whatever else you wanted to do. The only requirement is that string of your username:password must be 50 chars or less, including the colon (:).
Posted: Sun Aug 31, 2014 4:11 pm
by Smotz
So you could do:
This is perfect! Thank you as always.
Can I have multiple lines for multiple usernames?
Will this affect the portal in anyway?
Posted: Sun Aug 31, 2014 5:11 pm
Smotz wrote: This is perfect! Thank you as always.
No
I think it will because the portal will have to use the username and password to connect to your controller. However, I believe Roberto has this implemented and working now so the portal can connect but I am not 100% positive. He (or someone else) will have to confirm this (also, I have not checked, but I'm sure you could check on the portal for some authentication).
Posted: Sun Aug 31, 2014 7:52 pm
by Smotz
No
Gotcha - Everything is working except the portal.
Roberto, can you chime in? I cannot figure out where on the portal to set this.
Posted: Sun Aug 31, 2014 7:54 pm
Not implemented yet.
Posted: Sun Aug 31, 2014 8:02 pm
by Smotz
rimai wrote:Not implemented yet.
Gotcha. Well, looks good so far!
Posted: Fri Dec 19, 2014 7:50 pm
by Sacohen
Was the Webserver Authentication enabled on the Portal after the update to the 1.1.1 libraries.
I uncommented it from my code and when I load the portal I get Unreachable Address and it pulls the info from the database.
When I comment it out again the portal works fine.
ReefAngel.Network.WifiAuthentication("Sacohen:xxxxxxxx");
With the xxx's representing my actual password.
It is in my setup section.
Does the password need to be the same as what the portal uses or the Portal key?
For example the portal or forum password maybe ABCDefgh but my Portal key is AbCdEfGh
Posted: Fri Dec 19, 2014 8:45 pm
by Sacohen
I tried changing my forum password to match my Portal Key and the Server Authentication in my code and still got Unreachable Address.
Posted: Sat Dec 20, 2014 9:47 am
Not implemented yet :(
I'll try to get to this next week.
Posted: Sat Dec 20, 2014 10:06 am
by Smotz
following
Posted: Sat Dec 20, 2014 1:20 pm
by Sacohen
Thanks Roberto
Posted: Sat Dec 20, 2014 5:26 pm
by pandimus
This wouldn't happen to be the reason I've been getting authentication errors is it?
Posted: Sat Dec 20, 2014 5:54 pm
by Sacohen
Authentication errors where???
Have you added the web authentication to your code?
Posted: Sat Dec 20, 2014 6:24 pm
by pandimus
I get it constantly on the Android app, I haven't added any code.
Posted: Sat Dec 20, 2014 6:56 pm
by Sacohen
Then no.
The Android app has the authentication in it already.
Try changing your timeout time and # of retries.
Posted: Sat Dec 27, 2014 4:02 pm
I added controller authentication username and password fields to your user profile page.
Please go there and enter the same username and password you coded in your controller.
The portal should recognize it and apply the authentication automatically.
Please let me know how it goes.
Posted: Sun Dec 28, 2014 11:54 am
by Sacohen
Where are the authentication username and password fields?
I don't see them.
I looked under the portal settings and nothing new is there.
Posted: Sun Dec 28, 2014 1:48 pm
On your forum user profile page.
It's a more secure place to have them stored.
Posted: Sun Dec 28, 2014 3:30 pm
by Sacohen
Works great. Thanks.
I don't really use the U-App, but it would need to be added to that when you have a chance.
The Andiod App works great.
I'll try to get Russ at Reftronic to implement something on this page.
