System wide configuration file is "C:\Program Files\Reef Angel Controller\hardware/tools/avr/etc/avrdude.conf"
Using Port : \\.\COM6
Using Programmer : stk500v2
Overriding Baud Rate : 115200
avrdude: Send: . [1b] . [01] . [00] . [01] . [0e] . [01] . [14]
avrdude: Recv:
avrdude done. Thank you.After attempting to upload the code, I can always upload my recent code that doesn't include the relay. I have tested the USB/TTL cable data connection with some cable testing devices I have and the cable is fine. I also have made sure that the correct COM Port is selected. And the RA+ receives test code fine. I will try the suggestions mentioned in the other posts when I return home. But I wanted to post this ahead of time in case any new info has arisen since I get back home. Thanks in advance and I'll let you know what the results are when I get home.
