Page 1 of 2
RANet Ready Dimmable LED Driver
Posted: Fri Jul 18, 2014 10:37 am
Hi Everyone,
This is the first prototype of a wireless RANet Ready Dimmable LED driver module.
[youtube]
http://www.youtube.com/watch?v=9mGxHA9Y57A[/youtube]
It's truly a wireless LED mini fixture. It is even powered by a battery to make it the ultimate in mobile fixture
Don't expect the batteries to last long. I just did this to show off
That small battery would only last for about 4 hours.
Re: RANet Ready Dimmable LED Driver
Posted: Fri Jul 18, 2014 12:22 pm
by cosmith71
What's the responsiveness like? Will it do lightning?
Posted: Fri Jul 18, 2014 12:23 pm
by 89delta
Very nice Roberto
Posted: Fri Jul 18, 2014 1:43 pm
cosmith71 wrote:What's the responsiveness like? Will it do lightening?
I'll have to test. I'm not sure it can.
Posted: Fri Jul 18, 2014 4:03 pm
Here is what I was able to achieve:
I think it looks pretty realistic
[youtube]
http://www.youtube.com/watch?v=V4lR5FkzCyk[/youtube]
Posted: Fri Jul 18, 2014 4:22 pm
by cosmith71
Nice!
Posted: Fri Jul 18, 2014 4:41 pm
Sweet
Posted: Sun Jul 20, 2014 2:44 pm
by jsclownfish
I'm already looking for good thunder sound bytes to go along with the lightening.
Posted: Sun Jul 20, 2014 4:24 pm
by jegillis
How much is all this new stuff going to cost me?
Posted: Sun Jul 20, 2014 4:36 pm
by pandimus
What are the specs on it?
Posted: Sat Jul 26, 2014 3:33 pm
by cosmith71
Any way to code this lightning into the current cloud software?
Posted: Sat Jul 26, 2014 4:00 pm
That sucks
I lost the code. I can't find it.
Posted: Sun Jul 27, 2014 5:58 pm
I found it
int a=random(5);
for (int i=0;i<a;i++)
int newdata=4095;
Wire.beginTransmission(0x40);
Wire.write(0x8+(4*2));
Wire.write(newdata&0xff);
Wire.write(newdata>>8);
Wire.endTransmission();
delay(20+random(50));
newdata=0;
delay(30+random(20));
delay(random(1000));
Posted: Sun Jul 27, 2014 6:12 pm
by cosmith71
Nice. I might steal it.
Posted: Mon Jul 28, 2014 7:33 am
by cosmith71
So would something like this:
int a=random(5);
for (int i=0; i<a; i++)
analogWrite(daylightPWMPin, 255);
analogWrite(daylightPWMPin, 0);
Essentially taking over for 5 seconds, cause any timing problems with anything else if it hits in the middle of, say, top-off or dosing?
Posted: Mon Jul 28, 2014 8:35 am
Looks good
Posted: Mon Jul 28, 2014 10:09 am
by cosmith71
It works great! Will try to post a video later.
Posted: Mon Jul 28, 2014 10:20 am
Is there a thread of the official(?) cloud/lightning code anywhere? If there is can we sticky it? If not, can we get one posted. Too often I see the requests for it, and no idea where to find it
Colin, you should post your code somewhere if you don't already have it.
Posted: Mon Jul 28, 2014 10:35 am
by cosmith71
Posted: Tue Jul 29, 2014 5:06 am
by Smotz
been considering upgrading my lights. I should probably hold off to see what happens here..
Posted: Wed Aug 27, 2014 6:47 pm
by GiraffeCat
How many channels is each driver going to have? Is this going to be a RANet Dimming Expansion?
What is the range of voltages it can handle? Fixed voltage input, or selectable/tolerant of 12 to 48 volt range?
LMK.
Thank You,
GC
Posted: Wed Aug 27, 2014 7:13 pm
Each module has 3 channels capable of delivering anywhere from 350mA to 1000mA each channel.
You can use a power supply from 12V all the way up to 48V, depending on the number of LEDs you want to have in each string.
Posted: Thu Aug 28, 2014 7:06 pm
by GiraffeCat
Does it need a separate power source to run the electronics, or does it sample from the led source?
Many uses this RANet has. (In Yoda speak)
Late,
GC
Posted: Thu Aug 28, 2014 9:19 pm
Yes, you will need a power supply to feed power to as many LEDs you wish to light up.
For example, 3 LEDs, you only need 12V, but for 12-13LEDs, you need 48V.
It's the same as the LDD drivers.
Each channel is configured individually so you can set them to run at different amperages if you wish. Anywhere from 250mA to 1000mA each channel.
Posted: Fri Aug 29, 2014 11:39 am
by GiraffeCat
Forgive me. Let me ask a different way.
Does the RANet LED Driver need a power source of its own - to run the wireless communication portion of the driver. ( Not the LED power source - A separate source independent of the led power source .)
LMK,
GC
Posted: Fri Aug 29, 2014 11:59 am
No....
It has a built-in DC-DC converter to reduce the 12V-48V down to 5V to run the internal circuit.
Posted: Sun Aug 31, 2014 4:18 pm
by GiraffeCat
Update? I'm sure more than one person is wondering how it's going.
LUK,
GC
Posted: Sun Aug 31, 2014 6:27 pm
Someone is already running it on his system
Maybe he will post some pics
Posted: Mon Sep 01, 2014 8:29 am
by jegillis
rimai wrote:Someone is already running it on his system
Pics will be here shortly dimmer is running great however my cheap ebay power supply burned out. Waiting on a new one to get here to take pics.
Posted: Fri Feb 13, 2015 5:37 pm
by Rodasphoto
How much do these cost and how can I order a couple of them?
