clouds and lightning
pabaloval
Post by pabaloval »
Hello, I have this in my controller PDE but I dont see the effects of clouds or lightning.
Is there something wrong?. I do not see why clouds or lightning?
please I need you if you look you see faulty.
// Autogenerated file by RAGen (v1.1.0.126), (12/03/2011 12:18)
// RA_120311_1218.pde
#define DisplayImages
#define DosingPumpSetup
#define DateTimeSetup
#define ATOSetup
#define MetalHalideSetup
#define SingleATOSetup
#define StandardLightSetup
#include <ReefAngel_Wifi.h>
#include <ReefAngel_EEPROM.h>
#include <ReefAngel_ATO.h>
#include <ReefAngel_LED.h>
#include <ReefAngel_Relay.h>
#include <ReefAngel_PWM.h>
#include <ReefAngel_Timer.h>
#include <ReefAngel_Memory.h>
//Cloud & Lightning effects
 byte ActinicPWMValue=0;
 byte DaylightPWMValue=0;
 byte ATOPWMValue=0;
    ReefAngel.PHMin=217;
    ReefAngel.PHMax=885;
    ReefAngel.SetTemperatureUnit(1);  // set to Celsius Temperature
    ReefAngel.FeedingModePorts = B00111000;
    ReefAngel.WaterChangePorts = B00111000;
    ReefAngel.OverheatShutoffPorts = B00000000;
    ReefAngel.LightsOnPorts = B00000000;
    ReefAngel.Relay.On(Port4);
    ReefAngel.Relay.On(Port5);
    ReefAngel.Relay.On(Port6);
byte ATOPWMValue=0;
    // Specific functions
    ReefAngel.SingleATOHigh(Port1);
    ReefAngel.MHLights(Port3);
    ReefAngel.DosingPump1(Port7);
    ReefAngel.DosingPump2(Port8);
// Cloud & Lightning effects - Calculate your regular sunrise/sunset PWM value
  // byte PWMSlope(byte startHour, byte startMinute, byte endHour, byte endMinute, byte startPWM, byte endPWM, byte Duration, byte oldValue)
  ActinicPWMValue=PWMSlope(12,45,21,45,0,100,100,ActinicPWMValue); //Actinic turn on at 7am, off at 7pm, and ramp up 0% to 50% PWM in 60 minutes
  DaylightPWMValue=PWMSlope(12,05,21,45,0,100,100,DaylightPWMValue); //Daylight turn on at 9am, off at 5pm, and ramp up 0% to 50% PWM in 60 minutes
  ATOPWMValue=PWMSlope(12,00,16,55,0,100,5,ATOPWMValue);
  pinMode(lowATOPin,OUTPUT);
  analogWrite(lowATOPin,ATOPWMValue);
void CheckCloud()
#define Clouds_Every_X_Days 1
#define Min_Cloud_Duration 7
#define Max_Cloud_Duration 15
#define Min_Clouds_per_Day 3
#define Max_Clouds_per_Day 5
#define Start_Cloud_After NumMins(14,30)
  // In this example, end could before 4:30pm
#define End_Cloud_Before NumMins(20,30)
  // Which could mean 250 minutes of clouds. We need to make sure the PWMSlope can accomodate 250 minutes of effects or unforseen result could happen.
#define forcecloudcalculation
  // Uncomment this to force the cloud calculation to happen in the boot process.
  static byte cloudchance=255;
  static byte cloudduration=0;
  static int cloudstart=0;
  static byte numclouds=0;
  static byte cloudindex=0;
  static int LastNumMins=0;
#ifdef forcecloudcalculation
  if (cloudchance==255)
#else
#endif
      cloudchance=random(100);
      // If we have cloud today
      if (cloudchance)
        lightningchance=random(100);
  if (cloudchance)
    //is it time for cloud yet?
        else lightningstatus=0;
        if (lightningstatus)
          DaylightPWMValue=100;
          ActinicPWMValue=100;
          DaylightPWMValue=0;
          ActinicPWMValue=0;
        delay(1);
      cloudindex++;
      if (cloudindex < numclouds)
      int x=0;
      else x=17;
      else x=35;
    if (lightningchance)
      int x=0;
      else x=57;
      else x=75;
  cstart*=60;
  cend*=60;
  if (n>cend) return PWMStart;
  //End Cloud & Lighting
Re: clouds and lightning
You are missing the following line on the loop function:
  CheckCloud();
When you add this line, you most likely get an error about sketch being too big.
If you do, open your ReefAngel_Features.h file on notepad and paste the below code over the entire contents of that file. The file is located at "Documents\Arduino\libraries\ReefAngel_Features" folder
 * Copyright 2010-11 Curt Binder
 * Licensed under the Apache License, Version 2.0 (the "License")
#define SIMPLE_MENU
#define wifi
#define DisplayLEDPWM
#define VersionMenu
#endif  // __REEFANGEL_FEATURES_H__
And finally the entire PDE with the above modification:
#define ATOSetup
byte ATOPWMValue=0;
byte ATOPWMValue=0;
  CheckCloud();
void CheckCloud()
#else
#endif
      if (cloudchance)
  if (cloudchance)
          DaylightPWMValue=0;
          ActinicPWMValue=0;
        delay(1);
      cloudindex++;
      int x=0;
      else x=17;
      else x=35;
      int x=0;
      else x=57;
      else x=75;
  cstart*=60;
  cend*=60;
pabaloval
Post by pabaloval »
even changing the ReefAngel_Features "folder in the sketch too large.
34356 bytes
How could i make it smaller, or to occupy less the effects of clouds and lightning?
Thank you.
You must be editing the wrong file.
You have to make sure you save before you try uploading the code.
This is the size with the same features above:
Binary sketch size: 31080 bytes (of a 32256 byte maximum)
pabaloval
Post by pabaloval »
I'm editing this file, and then save the
Binary sketch size: 34456 bytes (of a 32256 byte maximum).
I'm doing wrong?
Thanks.
#define ATOSetup
byte ATOPWMValue=0;
byte ATOPWMValue=0;
  CheckCloud();
void CheckCloud()
#else
#endif
      if (cloudchance)
  if (cloudchance)
          DaylightPWMValue=0;
          ActinicPWMValue=0;
        delay(1);
      cloudindex++;
      int x=0;
      else x=17;
      else x=35;
      int x=0;
      else x=57;
      else x=75;
  cstart*=60;
  cend*=60;
It's not this PDE file that is wrong.
You need to edit the ReefAngel_Features file with the above contents.
It is located at "Documents\Arduino\libraries\ReefAngel_Features".
pabaloval
Post by pabaloval »
I'going crazy, but I edit the reefangel_features file not get it to go well.
So, did you mean it worked or not?
pabaloval
Post by pabaloval »
Not worked 34456 bytes
pabaloval
Post by pabaloval »
Now I'm not ay home. Later I send you mesage when I'm at home.
Thank you very much.
pabaloval
Post by pabaloval »
rimai wrote:It's not this PDE file that is wrong.
Hello as had to edit sketch ReefAngel_Features to build more than 30,720 bytes ??
thank you. I returned to resume the controller ReefAngel
