SALINITY MODULE
jcondello
SALINITY MODULE
Post by jcondello »
Hi my sal module just just stopped working stuck on 6 reading, i have worked out the data cable & power cable are fine, so it must be the module or the probe itself can any one tell me how i can check to see if the probe it dead with a multi meter ?
thank you !
Re: SALINITY MODULE
Use a paper clip to short out the BNC connector in the module itself. That way you can know if the module is working.
Do you get readings?
jcondello
Re: SALINITY MODULE
Post by jcondello »
OK shorted the bnc and i get 66, when open i get 6 ?, can anyone tell me if this is a normal reading from a working module ?
Re: SALINITY MODULE
The module seems to be working if it shows numbers other than 6.0, which leads us to the probe.
Did you try cleaning it?
jcondello
Re: SALINITY MODULE
Post by jcondello »
Yes I have with no luck ??
Re: SALINITY MODULE
PM me if you want to send it back for me to look at it.
