SALINITY MODULE
Posted: Sat Jul 19, 2014 11:15 pm
by jcondello
Hi my sal module just just stopped working stuck on 6 reading, i have worked out the data cable & power cable are fine, so it must be the module or the probe itself can any one tell me how i can check to see if the probe it dead with a multi meter ?
thank you !
Re: SALINITY MODULE
Posted: Sun Jul 20, 2014 10:36 am
Use a paper clip to short out the BNC connector in the module itself. That way you can know if the module is working.
Do you get readings?
Re: SALINITY MODULE
Posted: Tue Jul 22, 2014 1:33 am
by jcondello
OK shorted the bnc and i get 66, when open i get 6 ?, can anyone tell me if this is a normal reading from a working module ?
Re: SALINITY MODULE
Posted: Wed Jul 23, 2014 8:20 am
The module seems to be working if it shows numbers other than 6.0, which leads us to the probe.
Did you try cleaning it?
Re: SALINITY MODULE
Posted: Thu Jul 24, 2014 6:55 am
by jcondello
Yes I have with no luck ??
Re: SALINITY MODULE
Posted: Thu Jul 24, 2014 8:11 am
PM me if you want to send it back for me to look at it.
