Error Code
- maineultraclassic
Error Code
I'm getting an Error 22:XML I/O code, what does this mean?
54gal Corner Bowfront with 30gal basement sump
- Sacohen
Re: Error Code
Where are you getting this error?
I get it on mu Android App and it basically means the app had problems communicating with the controller at that moment.
- maineultraclassic
Re: Error Code
I was just going to post that..................I'm using the Android App, and I get this error code a lot.
- Sacohen
Re: Error Code
What is your Automatic Updating Interval set to?
I have mine at 10 min with a 30 second timeout and 3 retries and a retry interval of 5 seconds.
If that doesn't lessen it to a point that you can deal with maybe Binder will chime in since he created and maintains that app and does a great job with it might I say.
- Contact:
Re: Error Code
i would try to increase the read connection timeout from 15 seconds to something a little larger. that error means that the datastream from the controller was cut off too soon and the xml parser did not get a complete set of the data.
i found this out earlier while helping someone debug the 16ch dimming module.
i also am making some big under the hood changes to how the app gets the data and what it uses. hopefully this will help out more. and i really need to see about improving those error messages...they are not as intuitive as i thought they would be.
