Page 1 of 2
Controllable Automatic Fish Feeder?
Posted: Wed Aug 06, 2014 3:49 pm
by paperdesk
I was in the process of purchasing an automatic fish feeder to use when I go on vacation, and happened across the Apex Auto Feeding Station. It looks amazing, however, it got me to wondering: Why pay for electronics in a feeder I already have a RA?
Isn't there a simple feeder that could be actuated by the RA? Anyone have a success story?
Ted
Re: Controllable Automatic Fish Feeder?
Posted: Wed Aug 06, 2014 3:58 pm
Posted: Wed Aug 06, 2014 4:04 pm
by paperdesk
Neat looking feeder, not much in terms of cost saving though.
Posted: Wed Aug 06, 2014 4:37 pm
by paperdesk
I'm looking into the Super Feeder, it seems to be pretty large, not sure I have space for something that size, but I can measure when I get home. Anyone know of other options? Seems there might be a simple digital feeder you could "modify" to actuate via the dimming ports . . .
Posted: Wed Aug 06, 2014 5:48 pm
by Sacohen
Posted: Wed Aug 06, 2014 6:43 pm
by paperdesk
Thanks Steve, I'm reading through the posts now!
Posted: Wed Aug 06, 2014 7:15 pm
by paperdesk
Would the Eheim Everyday Feeder work too or just the "Feed-Air"? Or possibly any feeder that has a "feed" button?
Posted: Wed Aug 06, 2014 7:18 pm
by Sacohen
Theoretically, any feeder with a feed button, but you would need to figure out the modification on it.
Posted: Wed Aug 06, 2014 7:34 pm
by paperdesk
The two Eheim feeders mentioned above look almost exactly the same, but I don't know how the wiring compares. I haven't heard anyone particularly liking the air system, I'm hoping the "Everyday Feeder" would work the same.
On another note, would the Apex feeder even work with the RA?
Posted: Wed Aug 06, 2014 7:58 pm
by paperdesk
Well I decided to order the "air" one in the hopes of replicating success!
Posted: Wed Aug 06, 2014 8:23 pm
The feeder that apex uses is from lifegard aquatics.
http://www.lifegardaquatics.com/product ... sh-feeder/
It's pretty simple to mod it too.
All you need is a small relay to close those 2 contacts to simulate the press of the button.
Posted: Wed Aug 06, 2014 8:49 pm
by paperdesk
I wondered if they were the same!
Posted: Thu Aug 07, 2014 5:20 am
by cosmith71
I think the "Everyday Feeder" is just a newer version/packaging of the "Feed Air". They're both model 3581.
Posted: Thu Aug 07, 2014 5:48 am
Theres another one i've seen posts on RC for that cost like $15 on ebay. Some chinese brand that looks pretty easy to hack.
Posted: Thu Aug 07, 2014 6:25 am
by paperdesk
I ordered the eheim, but like the look of the intelli-feed. The eheim was under $30 so probably it's a better model to play with in case I toast something!
Posted: Thu Aug 07, 2014 6:35 am
by Sacohen
I toasted my first one because I suck at soldering.
I haven't attempted it again on the 2nd one yet.
Posted: Thu Aug 07, 2014 8:47 am
by paperdesk
Yah, I'm not very good either, especially with the really small stuff. However, I'm getting better with practice, and hope I can pull this off.
Posted: Thu Aug 07, 2014 8:58 am
by Sacohen
It' not that they are small solder point (which they are) it that they are SMD (Surface Mounted) so then tend to unsolder and slide off where they are supposed to be.
I think I melted the push button switch on my first feeder.
I was taught to solder by letting the things being soldered get hot and the put the solder on them.
Obviously SMD has to be done differently.
I think you have to tin the soldering iron and the wires you are adding to the contacts and use flux on the contacts that you are soldering to and then just touch the iron to the area to be soldered, and the solder will transfer off the iron to the area that is fluxed.
Posted: Thu Aug 07, 2014 9:10 am
by paperdesk
Sacohen wrote:It' not that they are small solder point (which they are) it that they are SMD (Surface Mounted) so then tend to unsolder and slide off where they are supposed to be.
I'm with you on this! I just discovered the same thing on a recent project. It turned out quite nicely after I figured it out! Still, I don't feel very confident working on these kinds of things.
Ted
Posted: Sat Nov 08, 2014 7:31 am
by Damion
What relay would you recommend?
Posted: Sat Nov 08, 2014 10:34 pm
by paperdesk
A Reef Angel!
Posted: Sun Nov 09, 2014 12:37 am
by Damion
Roberto, what specific relay would you recommend on the intelli-feeder?
Posted: Sun Nov 09, 2014 6:20 am
Use something like this to be safe:
http://m.ebay.com/itm/310566336050?nav=SEARCH
Sent from my Galaxy S5 with Tapatalk
Posted: Sun Nov 09, 2014 3:22 pm
by Damion
Posted: Tue Nov 25, 2014 3:52 pm
by Damion
Are you shorting the output of the relay to simulate a button press or applying voltage?
Posted: Wed Nov 26, 2014 8:56 am
by Sacohen
The way it has been done on the Ehiem Auto Feeder is we are applying 12v current to a relay that in turn is closing the connection for the feeder button and rotating the feeder chamber. Simulating a push of the button.
Posted: Wed Nov 26, 2014 9:23 am
by Damion
Thanks Steve,
I think I understand, you're using a relay to activate their relay?
Posted: Wed Nov 26, 2014 9:26 am
by Sacohen
Yes, if they are using a relay.
Posted: Wed Nov 26, 2014 8:24 pm
by wideawake
I have some relays similar to this and honestly I have no idea how to wire it and program it with the RA.
Any low level tips or links to a tutorial site would be much appreciated.
Posted: Thu Nov 27, 2014 7:54 am
