Jebao WP25 controller or no controller?
Posted: Fri Aug 08, 2014 12:32 pm
by paperdesk
I'm ordering a set of Jebao WP25's, and will be hooking them up to my "soon to arrive" RA. I can save a few dollars by buying just he pumps without a controller, or pay a little more and get the standard controllers, or again pay a few more dollars and get the twin controller. With the RA would I have a need for any of those controllers?
Ted
Re: Jebao WP25 controller or no controller?
Posted: Fri Aug 08, 2014 1:19 pm
It's always good for resale or for testing if you have an issue. If you don't get something you won't be able to do anything with your soon to arrive RA.. if that's ok with you then just wait and save a few $$.
Posted: Fri Aug 08, 2014 1:29 pm
by paperdesk
lnevo wrote:It's always good for resale or for testing if you have an issue. If you don't get something you won't be able to do anything with your soon to arrive RA.. if that's ok with you then just wait and save a few $$.
Good point about the testing, probably worth a few dollars for that!
Ted
Posted: Fri Aug 08, 2014 4:01 pm
by cosmith71
I would definitely get one just to have around.
Posted: Sat Aug 09, 2014 4:35 pm
by Sacohen
Get at least 1 controller.
My 40 stopped working a couple of weeks ago and after my normal trouble shooting o got no where
I plugged the pump into my controller.l and it worked fine.
Turns out something in the RA cable burned out.
Got a new cable and everything is fine now.
Posted: Mon Aug 11, 2014 9:37 am
by Piper
Definitely pick up the stock controllers. You'll eventually need to clean the pumps. I like to put them in a small 2 gallon paint pot and run them with bleach and water to clean them. You'll need the controller to do that.
Posted: Wed Aug 13, 2014 9:25 am
by paperdesk
Thank you for the excellent advice. I ordered pumps with controllers!
