Malfunctioning Tem Probe.
Posted: Mon Aug 11, 2014 6:57 am
by Sacohen
I have a 3' temp probe with the Temp extension.
I started having problems with the readings off of this probe and after looking at everything I noticed that the middle pin on the plug that goes into the RA was pushed up and not making contact.
How can I push this back down and have it stay in place?
Re: Malfunctioning Tem Probe.
Posted: Mon Aug 11, 2014 7:21 am
by cosmith71
Push it back in. If it won't stay, there's a little tab (the silver part visible in the holes in your picture) that you may need to bend up a little before you slide it back in.
Posted: Mon Aug 11, 2014 7:24 am
by Sacohen
The problem is that it's not all the way out or in. It's kind of stuck where it's at.
I don't want to pull to hard and pull the wire off
Posted: Mon Aug 11, 2014 7:26 am
by cosmith71
Push it in with something pointy, like a paperclip.
Posted: Mon Aug 11, 2014 7:29 am
by Sacohen
Thanks. I'll try it later.
