Wifi Module Solid Red and Yellow
Posted: Mon Aug 11, 2014 4:19 pm
by paperdesk
I just got my RA and wifi attachment, but am having trouble getting the wifi attachment to work. I got to a point where the wifi attachment had a slow blinking green light, and an IP address of 0.0.0.0.2000. I tried running through the programming again toget a proper IP address but to no avail. Now, however, the red and yellow lights have gone on and stay on solid.
What to do now?
Re: Wifi Module Solid Red and Yellow
Posted: Mon Aug 11, 2014 4:28 pm
by paperdesk
And it gives me an error code:
ERROR - Please disconnect and then reconnect the Reef Angel Wifi Attachment from the USB-TTL cable and try again.
Posted: Mon Aug 11, 2014 5:06 pm
Red and yellow solid is not normal. Please PM for RMA.
Posted: Mon Aug 11, 2014 5:34 pm
by paperdesk
I have another FTDI device I used that I thought might be causing problems, but it's on another COM port, so I think that is ruled out.
I'll PM you about the RMA.
By the way, for the record, I connected via Teraterm, and got the following Gibberish:
3e ó¤l
8ÿ{4$Ðý3e¤;e ó¤dÿs?¼Æ×þó¤l
ó¤|?¼ÆÕþ;¢s¦d¬ó¤|ÿy4,Æ ýó¤d¬
s¦d¬3eÿs?<?ó¤l ýó¦d¬
3§d¬ó¤\ÿ³ü´%ÆÑýó¤l
9ÿ³4$ÆÉýó¤|
3¢3§dÿ³4$ÆÉý;£s¦d¬ó¤\ÿ3?¼ÇÑÿó¤l
8
9ÿ{?¼ÆÖý3e ó
9ÿ{<Æ ý#
8
ó¤|ÿx4$Ðý9
ó¤|
;ÿx4$ÆÉý3e s¦d¤9ÿs?¼Æ3e
Posted: Mon Aug 11, 2014 6:11 pm
by paperdesk
I tried to replace the firmware via Teraterm as outlined here
and got more gibberish. After setting the baud rate to 57600 I got the following:
*FAIL*, handshake
EAP TRY #3
*FAIL*, handshake
EAP-TLS Client APP version 1.00 10/11/12
*FAIL*, handshake
EAP TRY #2
*FAIL*, handshake
EAP TRY #3
*FAIL*, handshake
Posted: Tue Aug 19, 2014 11:43 pm
by paperdesk
Ok, I got the replacement attachment and it works! However, I'm a little confused about the wifi test code. When I upload the wifi test code it shuts down everything in my tank. Does this mean that it is replacing my current sketch? I re-uploaded my previous sketch and was up and running again. I am able to view my tank info in the demo server occasionally and often get an "unable to connect to the server" message. Then, mysteriously, it will sometimes work.
I can currently view my info in the portal and the demo server, though under "connection" in the portal it says "unreachable address".
Posted: Wed Aug 20, 2014 5:33 am
The test code is just a test, you have to put your ino back when done testing. Unreachable means your port forwarding needs to be setup.
Posted: Wed Aug 20, 2014 8:21 am
by paperdesk
OK got it. Thought port forwarding was good but will double check settings.
Posted: Fri Aug 29, 2014 12:49 pm
by paperdesk
Got it all ironed out, somehow one of the settings didn't "take" the first time, but it's working now!
