RobertoFlow Drain Pipe
Posted: Fri Aug 29, 2014 9:58 am
Our community members decided to give this a name
http://forum.reefangel.com/viewtopic.php?p=42105#p42105
So, I decided to create a tutorial page, so we can find it easy for future reference
The problem:
I've tried all different versions of stand pipe and they all have something in common... You must inject air into the drain pipe to avoid full siphon. I doesn't matter which one you use. You will always end up with cascading noise, even if it is minimal and a lot of bubbles in your sump.
I only have one drain pipe, so I can't really use those full siphon version with 3 pipes.
The solution:
Use a Reef Angel coupled with a water level expansion and a Speedwave pump to control the flow of your drain based on the overflow water level, so you have a dead silent drain pipe
Don't mind the mess... Here is a video:
[youtube]http://www.youtube.com/watch?v=r15TTX-KHZw[/youtube]
And here is the code I was using:
The problem:
The solution:
#define Level 50
#define MinPWM 50
#define OperatingPWM 66
long nummillis=5000;
byte PWMValue=0;
boolean override=false;
InternalMemory.WaterLevelMax_write(1800);
PWMValue=OperatingPWM;
if (ReefAngel.WaterLevel.GetLevel()<Level-2)
override=true;
PWMValue+=2;
if (ReefAngel.WaterLevel.GetLevel()>Level+2)
override=true;
PWMValue-=2;
if (millis()-lastmillis>nummillis && override)
override=false;
if (!override) PWMValue=OperatingPWM;
if (ReefAngel.WaterLevel.GetLevel()>Level+10) PWMValue=MinPWM;
PWMValue=constrain(PWMValue,MinPWM,100);
ReefAngel.PWM.SetActinic(PWMValue);
ReefAngel.LCD.DrawDate(6, 122);
ReefAngel.LCD.DrawMonitor(15, 60, ReefAngel.Params,
ReefAngel.LCD.DrawMonitor(15, 60, ReefAngel.Params);
ConvertNumToString(text, ReefAngel.WaterLevel.GetLevel(), 1);
strcat(text," ");
ReefAngel.LCD.DrawText(DefaultFGColor,DefaultBGColor,15,93,"Water Level:");
ReefAngel.LCD.DrawText(DefaultFGColor,DefaultBGColor,88,93,text);
ReefAngel.LCD.DrawOutletBox(12, 103, TempRelay);
ReefAngel.LCD.DrawGraph(5, 5);
