Analog dimming
Posted: Fri Aug 29, 2014 1:27 pm
by Cromanon
How I connect a relay box analog with analog LED , if there is a better drawing.
Thank you.
Re: Analog dimming
Posted: Tue Sep 02, 2014 10:22 am
by Sacohen
If I get you correctly you want to connect analog LED's to and analog Relay box?
Just connect them to the analog dimming ports on the side of the relay box.
You may need to modify you LED connections to have the header plug that the dimming ports use.
Re: Analog dimming
Posted: Tue Sep 09, 2014 3:06 pm
by Cromanon
ok, thanks.
