ATO using Water Level Expansion
Posted: Wed Sep 03, 2014 7:24 pm
Hi guys,
I'm looking to set up ATO using my water level expansion but i'm a little clueless on how to code it all. Anyone have any ideas? Another quick question when you set the High and Low parameters in % what does each mean? Is low the level at which the pump will turn on and high when it will turn off? Is there some way to set up an alarm using the float valves so that when the float valve activates (above the high mark for the ato) it shuts off my ato pump? just as a secondary precaution.
Also not sure if this belongs here but is there a guide somewhere on setting up email notifications and stuff? So i can be alerted if temperature overheats or drops or salinity has problems etc?
Cheers guys,
Slowly getting the hang of this equipment
Cheers guys,
