Trouble setting up RF Addon
Posted: Sat Sep 13, 2014 2:50 pm
I recently got the RF module. Haven't had time to really work on custom coding for it yet, but I wanted to get it up and running using RA wizard. Decided to have it default on to Nutrient Transport mode. (code set up by wizard). I reset the memory on my two vortechs, then uploaded my code. The RF module's LED is purple so it is in Nutrient Transport mode. Can't set my vortechs to slave mode. The pump controllers and RF module are literally next to each other. Pumps keep flashing red and blue after trying to set them as slaves (not communicating). I must be missing a setup step to formally set the RF module to master and the pumps to slave. Need some help. Thanks, Casey
// Custom menus
#include <avr/pgmspace.h>
prog_char menu1_label[] PROGMEM = "Reset Skimmer";
prog_char menu2_label[] PROGMEM = "Reset Return Pump";
prog_char menu3_label[] PROGMEM = "ATO Clear";
prog_char menu4_label[] PROGMEM = "Overheat Clear";
prog_char menu5_label[] PROGMEM = "pH Calibration";
prog_char menu6_label[] PROGMEM = "PHE Calibration";
prog_char menu7_label[] PROGMEM = "Salinity Calibration";
prog_char menu8_label[] PROGMEM = "WL Calibration";
prog_char menu9_label[] PROGMEM = "Date / Time";
menu4_label, menu5_label, menu6_label,
menu7_label, menu8_label, menu9_label
boolean overflow_plugged = false;
boolean skimmate_full = false;
boolean calcium_low = false;
boolean alkalinity_low = false;
ReefAngel.AddPHExpansion(); // pH Expansion Module
ReefAngel.FeedingModePorts = Port4Bit | Port8Bit;
ReefAngel.WaterChangePortsE[0] = Port2Bit;
ReefAngel.LightsOnPorts = Port5Bit | Port6Bit;
ReefAngel.OverheatShutoffPorts = Port3Bit | Port5Bit | Port6Bit;
ReefAngel.Relay.On( Port1 ); //VorTech MP40
ReefAngel.Relay.On( Port2 ); //VorTech MP10
ReefAngel.Relay.On( Port4 ); //Return Pump
ReefAngel.Relay.On( Port8 ); //Skimmer
ReefAngel.Relay.On( Box1_Port3 ); // Unused
ReefAngel.Relay.On( Box1_Port4 ); // Unused
ReefAngel.Relay.On( Box1_Port5 ); //4 Channel Dosing Pump
ReefAngel.Relay.On( Box1_Port6 ); //Sump Light
ReefAngel.Relay.On( Box1_Port7 ); //pH Expansion
ReefAngel.Relay.On( Box1_Port8 ); //Salinity Expansion
ReefAngel.CustomLabels[0]="VorTech MP40";
ReefAngel.CustomLabels[1]="VorTech MP10";
ReefAngel.CustomLabels[2]="Heater";
ReefAngel.CustomLabels[3]="Return Pump";
ReefAngel.CustomLabels[4]="Actinics";
ReefAngel.CustomLabels[5]="Daylight";
ReefAngel.CustomLabels[6]="Blue Moon";
ReefAngel.CustomLabels[7]="Skimmer";
ReefAngel.CustomLabels[8]="Swabbie";
ReefAngel.CustomLabels[9]="ATO";
ReefAngel.CustomLabels[10]="Unused";
ReefAngel.CustomLabels[11]="Unused";
ReefAngel.CustomLabels[12]="Dosing Pump";
ReefAngel.CustomLabels[13]="Sump Light";
ReefAngel.CustomLabels[14]="pH Exp";
ReefAngel.CustomLabels[15]="Salinity Exp";
ReefAngel.StandardHeater( Port3,780,800 );
ReefAngel.StandardLights( Port5,7,0,19,0 ); // Actinics
ReefAngel.StandardLights( Port6,8,0,18,0 ); // Daylight
ReefAngel.StandardLights( Port7,19,0,0,0 ); // Blue Moon
ReefAngel.DosingPumpRepeat( Box1_Port1,0,240,30 ); // Actually controlling swabbie.
ReefAngel.StandardATO( Box1_Port2,120 );
ReefAngel.PWM.SetDaylight( PWMSlope(8,0,18,0,10,100,60,10) );
ReefAngel.PWM.SetActinic( PWMSlope(7,0,19,0,10,100,60,10) );
ReefAngel.RF.SetMode( NutrientTransport,45,40 );
/// set custom variables for portal
ReefAngel.CustomVar[0] = overflow_plugged;
ReefAngel.CustomVar[1] = skimmate_full;
ReefAngel.CustomVar[2] = calcium_low;
ReefAngel.CustomVar[3] = alkalinity_low;
static byte sump_level=0;
static byte overflow_level=0;
sump_level= ReefAngel.WaterLevel.GetLevel (0);
overflow_level= ReefAngel.WaterLevel.GetLevel (3);
if (((sump_level < 50) or (overflow_level > 75)) && (millis()>1000)) { // Turn off sump if overflow begins to crest and
overflow_plugged = true; // sump level drops when overflow is obstructed.
bitClear(ReefAngel.Relay.RelayMaskOff,3);
ReefAngel.LED.On();}
if (((sump_level >= 80) or (sump_level < 40)) && (millis()>1000)) { // Toggles skimmer on and off if sump depth too great.
ReefAngel.Relay.Off (Box0_Port8);} // Avoids skimmer overflow. Used this code instead of delayed start for skimmer.
if ((sump_level <= 76) && (sump_level > 45)) { // Otherwise skimmer is on unless sump level too low.
ReefAngel.Relay.On (Box0_Port8);}
static byte skimmate_level=0;
skimmate_level = ReefAngel.WaterLevel.GetLevel (1);
if (skimmate_level > 75) {
skimmate_full = true;}
if (skimmate_level < 70) {
skimmate_full = false;}
if (skimmate_level > 80) { // Turn off skimmer when skimmate container is full.
bitClear(ReefAngel.Relay.RelayMaskOff,7);
static byte calcium_level=0;
calcium_level = ReefAngel.WaterLevel.GetLevel (4); // Alert when calcium tank is low.
if (calcium_level < 10) {
calcium_low = true;}
if (calcium_level > 20) {
calcium_low = false;}
static byte alkalinity_level=0;
alkalinity_level = ReefAngel.WaterLevel.GetLevel (2); // Alert when alkalinity tank is low.
if (alkalinity_level < 10) {
alkalinity_low = true;}
if (alkalinity_level > 20) {
alkalinity_low = false;}
ReefAngel.Portal( "windsweptfarm" );
///Custom Menu Functions
void MenuEntry1()
bitSet (ReefAngel.Relay.RelayMaskOff,7);
ReefAngel.LED.Off();
ReefAngel.DisplayMenuEntry ("Reset Skimmer");
void MenuEntry2()
bitSet (ReefAngel.Relay.RelayMaskOff,3);
ReefAngel.DisplayMenuEntry ("Reset Return Pump");
void MenuEntry3()
ReefAngel.ATOClear();
ReefAngel.DisplayMenuEntry ("Clear ATO Timeout");
void MenuEntry4()
ReefAngel.OverheatClear();
ReefAngel.DisplayMenuEntry ("Clear Overheat");
void MenuEntry5()
ReefAngel.SetupCalibratePH();
void MenuEntry6()
ReefAngel.SetupCalibratePHExp();
void MenuEntry7()
ReefAngel. SetupCalibrateSalinity();
void MenuEntry8()
ReefAngel.SetupCalibrateWaterLevel();
void MenuEntry9()
ReefAngel.SetupDateTime();
