Dimmable Lunar Hub not work
Posted: Tue Sep 16, 2014 11:47 am
I have got the Dimmable Lunar Hub and connected to the Daylight dimming port on the relay box. However, I cannot find noticeable dimming effect and it lights up even in the last new moon.
Then, I tried to connect the LED directly to the daylight dimming port and it has dimming effect. The connections and program were checked but found nothing incorrect. Finally I examined the circuit board and checked whether there is any abnormal. It was found that the transistor Q1 was not in place as shown below. Is it normal?
