Wifi Stopped Working
Posted: Wed Oct 01, 2014 7:03 pm
by csmith
The unit randomly stopped working. I did not update my ino file or my router / wifi module configuration. I have tried resetting to factory defaults using the Wifi utility and the wifi module will work for a short period of time before randomly failing again. Any ideas? This feels like a hardware issue. I tried to post a video but I don't have enough posts. The units flashes Red Yellow Blue in sequence while simultaneously rapid flashing green.
Re: Wifi Stopped Working
Posted: Wed Oct 01, 2014 8:48 pm
If you did firmware upgrade, you need to follow this:
Posted: Thu Oct 02, 2014 5:37 pm
by csmith
Roberto- I actually had the firmware problem in the past and was able to fix it following the link that you posted. This unit was working perfectly for months and then quit randomly a few nights ago. There were no changes to the INO or the wifi unit within a week of it failing. The LED indicator sequence seems very odd. I cant post a link to the video yet but if you were to add the youtube prefix followed by "/QPM1N57tWEY" you can view it. What is weird is that I get the light sequence when it is plugged into the controller and when I try to reset the factory defaults or input a new password using the wifi app (I am not trying to upgrade the firmware).
Posted: Fri Oct 03, 2014 8:13 am
There is a little pinhole on the side of the wifi attachment. If you use a paper clip to push the button inside, does it change anything? You may need to press it several times.
I think you may need to send it back.
PM me if you want to send it back for analysis.
