error uploading to new board.
Posted: Mon Oct 06, 2014 6:39 pm
by pandimus
i configured the new plus controller like the old controller pins etc put on screen and put in case..
this is the error i get
Copyright (c) 2000-2005 Brian Dean,
http://www.bdmicro.com/
Using Port : \\.\COM5
Using Programmer : stk500v2
Overriding Baud Rate : 115200
avrdude: Recv:
avrdude done. Thank you.
any ideas?
Re: error uploading to new board.
Posted: Mon Oct 06, 2014 9:18 pm
Are you sure it is the correct serial port?
Posted: Mon Oct 06, 2014 10:44 pm
by pandimus
I've tried 5 and 1, reset computer, tried scanning the usb port. Nada. I am using the modified usb cable for power, shouldn't be a problem though worked fine on old angel..
Posted: Mon Oct 06, 2014 11:04 pm
by pandimus
One other thing... The screen lights up but is blank
Posted: Tue Oct 07, 2014 8:26 am
The screen may be because it is an old screen and needs a setting in the internal memory to be changed.
Does any of your relay ports turn on?
Posted: Tue Oct 07, 2014 4:14 pm
by Piper
Did you go from a RA to a RA+? Did you select the RA+ for board type in the menu?
Posted: Wed Oct 08, 2014 1:24 pm
by pandimus
Definitely in plus mode. I hooked it up and got no power on any relays. The jumpers that were on the board on upper left I removed those because I thought that's how other board was setup, but noticed today three jumpers lower right on old board. Could this be in?
Posted: Wed Oct 08, 2014 1:44 pm
by Piper
You need to have the 3 jumpers in place near the lower middle of the board. Just from from the LCD if I remember correctly.
Posted: Wed Oct 08, 2014 7:53 pm
by pandimus
I couldn't remember the jumpers I removed/changed when I added my dimming module
Posted: Thu Oct 09, 2014 11:36 am
by pandimus
Well it's uploading now that I put the three jumpers on, still no screen and no relay activities I'll investigate a little more this weekend
Posted: Thu Oct 09, 2014 11:42 am
Is it an old screen?
I think you need this in your setup() right above ReefAngel.Init();
Posted: Thu Oct 09, 2014 11:57 am
by pandimus
rimai wrote:Is it an old screen?
It is the same screen that I got with the used reef angel standard I got a few years ago, so I guess it's safe to say yes.. I'll give that a try.
Posted: Thu Oct 09, 2014 12:52 pm
by pandimus
OK that code worked to get screen runnjng
This is why nothing has worked
Posted: Thu Oct 09, 2014 12:53 pm
Ahhh.. There ya go
Posted: Thu Oct 09, 2014 2:26 pm
by pandimus
What does that message on screen mean?
Posted: Thu Oct 09, 2014 3:37 pm
Means its time to upload your INO file
Posted: Fri Oct 10, 2014 10:51 am
by pandimus
I get this message if. I try to upload my code to the ra+, if I put on any of the test codes they load up normally.. What's happening?
Posted: Fri Oct 10, 2014 12:37 pm
Can you post the code.
Posted: Fri Oct 10, 2014 3:09 pm
by pandimus
Well.... I went up to get code. Had a test code on controller, I decided to upload the code I made from wizard.. And what bam thank you ma'am worked like a champ.. Not sure what happened but it's working great now.. Thanks for help, now I can use all the 110 features..
