Reef Angel dead after power outage
Posted: Mon Oct 06, 2014 9:42 pm
by psyrob
When I got home from work I found that power had gone out and then came back on in my fish room. Now, my controller screen is dark, I have a solid green and red light on the controller and nothing is working that is plugged into the box. Did this fry a fuse or is my unit dead? Any ideas on how to trouble shoot this? I tried the obvious, unplugging the box, unconnectong the controller from the box, etc
Rob
Re: Reef Angel dead after power outage
Posted: Tue Oct 07, 2014 8:27 am
Try unplugging everything and use the usb power cable. Does it work?
Posted: Tue Oct 07, 2014 9:44 pm
by psyrob
yes, the screen is back up and running when I use the usb power cable...next step?
Posted: Tue Oct 07, 2014 9:49 pm
by psyrob
ok, pulled the usb cable out and the controller is still working. wifi isn't tho, the blue light blinks like eight times, pauses then blinks at the same rate.
Posted: Wed Oct 08, 2014 8:17 am
That means it is not connected.
Try configuring it again. It should have reconnected though.
